Old 08-11-2017, 12:51 PM
Lititzflyer Lititzflyer is offline
Default Fuselage or wings
Anyone have recommendations on which kit to build after the empennage. Wings or fuselage or does it matter?
Thanks.
Kevin
Old 08-11-2017, 01:03 PM
Model 12 Model 12 is offline
Good question,I was sorta wondering the same thing?
Old 08-11-2017, 01:17 PM
AeroDog AeroDog is offline
Thanks.
Kevin
I did the fuse first, then the wings. Should have done it the other way. Do the wings. Van's has reasons for the order they recommend.
Jerre
Empennage and fuselage kits complete
Wing kit compete, Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 08-11-2017, 02:38 PM
fr0gpil0t fr0gpil0t is offline
I'm finishing off the tail kit. I agree wings and then fuselage. But wing kits are 20 weeks out and the new fuselage kits 12 weeks. So plan ahead unlike I did ;-)
Old 08-11-2017, 03:38 PM
Steenos Steenos is offline
I haven't started building yet, but it depends on what you want to go with. If you want to go with RV12iS I spoke with vans today and they said the new Fuselage should be around October. That could give you plenty of time to work on the wings. Just my .02
Old 08-11-2017, 04:33 PM
rongawer's Avatar
rongawer rongawer is offline
Default Fuselage first
I recommend savings the wings until the end. I did it all out of order...and it worked out fine.
I recommend getting the entire fuselage finished and then do the wings for the simple reason that you'll just be storing the wings until your done anyway, unless you just want to do them first.
There's no compelling process or design reason that you need to do the wings before the fuselage. The only section that is affected is #30, which is fitting the wings. And there's no reason you can't do that once the entire airplane is done anyway.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
Old 08-11-2017, 04:37 PM
haha I like your sig 90% done and 90% to go. How frustrating is the build process?
Old 08-11-2017, 05:22 PM
Generally, it's easier to store tail surfaces and wings than a fuselage. If you have plenty of room, great; pick your poison.
I built my -7 'in order'; tail, then wings, then fuselage. Everything in a ~20' x 22' space, with a 5x7 corner notched out for a bathroom. Also in the room are multiple shelving racks, two rolling tool boxes, a tool table with a benchtop drill press, and a 4x6 work table. Tail is on shelving, and wings are strapped to the ceiling, making room for the fuselage. If I'd built the fuselage 1st, it would have to go somewhere else to live while I built the rest.
Charlie
Old 08-11-2017, 05:54 PM
DonFromTX's Avatar
Lots of great guidance here, but something to consider is that the wings are completed in a week or so, the fuselage takes LOTS longer.
AF1 (was RV12) EAB Air Force One, SN 461, N461DG VIKING/HONDA ENGINE POWERED! AND N756TS ROTAX POWERED
Retired US Army Officer
http://www.mykitlog.com/users/index....X&project=1903
Old 08-12-2017, 05:08 AM
HansLab HansLab is offline
I did the same thing as Ron: start with the fuse first.
Reason was the complexity of this part of building. To be honest: mostly because we put in an entirely MGL-panel, including home-made wiring.
However: having done the fuselage (almost now) there ain't much the wings can learn us, anymore. That should be a no-brainier, specially because there are two fairly the same of'm.
Nice spin-off of starting with the fuse is that we can take all our time to get the cockpit and surroundings as complete and beautiful as we want.
Just my .02, though.
Hans Labruyere
build & sold project Kitfox IV
Bought project & building RV12 #120742
