Go Back   VAF Forums > Model Specific > RV-4
Old 08-10-2017, 08:29 PM
NorthernRV4's Avatar
NorthernRV4 NorthernRV4 is offline
Default Countersinking the main spar skin rivet holes
I am ready to countersink the skin rivet holes in the main spar flange on my -4 spars and I'm going in circles on whether to machine countersink or dimple countersink the holes. Tech Support said it wouldn't matter from a structural standpoint to do it either way. I've already dimpled my aft spar flanges with good results but I can't really comment about possibly distortion since I have not mated my wing skins (yet to be dimpled) to them again.
I'm leaning toward dimpling the main spar flanges (.040") with my pneumatic followed by a hand squeezer to crisp them up. If I need to touch them with a microstop after that to remove a thousand or two then I can. The main reason I'm leaning this way is that I find the skin dimple nests into a dimpled substructure better than a machine c/s even when machining .006-.007" deeper than flush as per Van's instructions. The newer kits are all thicker flanges so dimpling is out of the question and there is many a thread about machine c/s these.
Anyone have some advice?
2017 VAF dues happily paid, Thanks DR!
Old 08-10-2017, 11:56 PM
You wont be crisping up dimples in .040 with your hand squeezer. A properly functioning pneumatic squeezer will form a dimple in .040 much better than you can by hand.
If you choose to dimple, a better process would be to lightly machine countersink after dimpling to make the dimple slighter deeper to receive the skin dimple.
Scott McDaniels
Hubbard, Oregon
Old 08-12-2017, 02:52 PM
True, even after hand squeezing the rivet head sits .007" below flush but it seems to flatten out the surrounding material a bit better, not quite sure why.
I guess I'm more concerned with the finish on the visible surface of the skins. I do plan on back riveting the top skins first and traditional bucking of the bottom skin rivets. I realize this is going to make bucking the aft spar more challenging since the flange faces forward into the wing but I want the topside to look as nice as possible. Seems like the depressions left from squeezing might show up more in the visible surface, if driving the rivets with a gun/bucking bar from the outside.
