Old 08-11-2017, 06:10 PM
snopercod's Avatar
Default Bearing packer?
May I ask a dumb question? What kind of bearing packer are people using? I see some of them have Zerk fittings and some don't. Which is better?
(2018 dues paid)
Old 08-11-2017, 06:21 PM
Larco Larco is offline
In my neck of the woods this is popular. I think if you shop this item it can had for less money else where, maybe.
https://www.napaonline.com/en/p/SER774005
Ironflight's Avatar
VAF Moderator / Line Boy
I've tried several of them - and always end up using the palm of my hand fingers to work the grease in, just the way my Grandad taught me a long time ago. The gimmicky ones just don't seem to do the job I'd like. The only change is that I wear nitrile gloves these day, because it makes it easier to clean up my hands afterwards.
On solvents, I had always been taught to use Stoddard Solvent for aviation work, and have done that for years too - but nowadays, its hard to find by that name. I did some research, and it turns out that Stoddard is another name for Mineral Spirits, so that is what I have been using lately. Much less likely to go "boom" than gasoline or Avgas (which I have also used in a pinch, but prefer not to take the risk if I don't have to.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-11-2017, 06:39 PM
RV6_flyer's Avatar
Sounds like the way I pack bearings. Dad taught me that way more years ago that I can remember.
Stoddard solvent is my preference if cleaning out all the way. Have been known to use mineral spirits, diesel fuel, and Jet A but NEVER gasoline or 100LL. Did not know mineral spirits and Stoddard solvent was the same thing. Around my airport, people talk about using Varsol. Sounds like we all use the same thing but has different names.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 08-11-2017, 07:31 PM
bret's Avatar
bret bret is offline
The 104 flash point safety clean was my favorite in a solvent tank, then emissions regulations started taking over and then 140 flash point, did not clean as well, then the orange juice solvent, then the heated water base with soap and live bugs that eat grease, take the parts out and then they would rust. Then they took our solvent tank away! so now we use cans and cans of brake clean........what fumes? bet you can't guess what state this is.........getting rid of hazard material is expensive. By the time you buy many cans of cleaner, you could probably buy new bearings and pack them.......
2018 gladly supported
Old 08-11-2017, 07:34 PM
Originally Posted by Mel View Post
NEVER spin a bearing with compressed air. If it is not packed with grease, you will put more wear on it in a few seconds than a lifetime of normal use.
As said before, just pack in new grease until the dirty grease is expelled.
That's what the Air Force taught me a long time ago when they were trying to make me into a helicopter mechanic. Both of these.
Originally Posted by gasman View Post
Re-pack with Sta-lube boat trailer grease from Napa Auto parts..... touch it and you will understand.
That's what I use on my C-180. Works great.
Old 08-11-2017, 07:39 PM
Mel's Avatar
Mel Mel is offline
Yep! That's the way I was taught by my Dad and that's the way I still do it.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-11-2017, 07:41 PM
koupster's Avatar
koupster koupster is offline
Default Diesel
I've started using diesel for most parts cleaning. It's much cheaper than mineral spirits; just take an empty gallon oil jug to the service station. If left uncovered when you're not around for a bit, most of the smell goes away.
Cheers, David
RV-6A A&P
Old 08-11-2017, 07:43 PM
plehrke's Avatar
plehrke plehrke is offline
Stoddard solvent or mineral spirits depending what I have and then rinse with brake cleaner. Always thought having the solvent residue left on the bearing could break down the new grease. Brake clean leaves very little residue.
A lot easier to inspect bearing for pitting if you clean them before packing with fresh grease.
Philip
RV-6A - 11 years over 800 hours
Cessna 140 - 68 years over 3400 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 08-12-2017, 10:22 AM
dspender dspender is offline
Sounds like mineral spirits and brake cleaner is the ticket. I have so much brake dust from dragging brakes I don't want to just push more grease in. Now working on what is dragging the brakes.
Dennis
