Old 08-10-2017, 07:55 PM
dspender dspender is offline
Default Cleaning wheel bearings
What type of solvent or name of a product should I use to clean the wheel bearings and wheel axle? Is gasoline ok? I think there must be something more effective or safe. I have taken the main tires and wheels off to rotate the tires and there is brake dust on the bearings and axle that I want to remove.
Dennis
Old 08-10-2017, 08:34 PM
Gasoline would be my last choice. For bikes, I used brake cleaner. I just hate the smell of gas and the blowing up part too.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 08-10-2017, 08:42 PM
BillL BillL is offline
I use mineral spirits. It does not dissolve the grease as fast as gasoline, but is safer. Compressed air is good to blow off the old grease and dry the bearing but be careful spinning it, the cage can expand and/or explode. Just be sure to use fresh for the last cleaning.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
33/40 hrs
Aerobatics DONE!!
2017 Dues Paid
Old 08-10-2017, 09:29 PM
Jrskygod Jrskygod is offline
100LL. Works great, readily available, dries fast, it's the all purpose cleaner. Probably not a good idea to smoke while using it tho.
Paid for 2018 + extra and well worth it!
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 08-10-2017, 09:44 PM
Kyle Boatright Kyle Boatright is online now
Mineral spirits, a throwaway cake pan, and an old toothbrush.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 08-10-2017, 10:15 PM
gasman gasman is offline
Wipe with paper towels. Spray with brake clean. Rinse with mineral spirits. Inspect. Re-pack with Sta-lube boat trailer grease from Napa Auto parts..... touch it and you will understand.
VAF #897
2017 =VAF= Dues PAID
Old 08-10-2017, 10:29 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Brake cleaner.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 08-10-2017, 10:41 PM
Michael Burbidge Michael Burbidge is offline
Default Nothing
I've read here that you shouldn't use a solvent. Simply pack with new grease until all the dirty grease is pushed out.
That's what I've done for three years now.
Michael
Michael Burbidge
Sammamish, WA
RV-9A Flying–265 hours so far!
Last Donation: December 2017
Old 08-10-2017, 10:42 PM
I've never cleaned mine. I inspect the race. If it's good, I inspect the bearing looking for any shiny flakes. Then I use a bearing grease packing tool and inspect the old grease that is forced out. If all is good, back in they go.
update: I'm Mike's shadow from above.
Old 08-11-2017, 06:44 AM
Mel's Avatar
Mel Mel is online now
Compressed air is good to blow off the old grease and dry the bearing but be careful spinning it, the cage can expand and/or explode. .
NEVER spin a bearing with compressed air. If it is not packed with grease, you will put more wear on it in a few seconds than a lifetime of normal use.
As said before, just pack in new grease until the dirty grease is expelled.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
