Old 08-10-2017, 08:54 AM
Default Installing brakes drawings?
Is there any better drawings than C2 about how to install the Cleveland brakes?
My question is on the right brake, I will need to move the zirk fitting from the top to the bottom so I can put the blue 90 degree fitting to connect to my brake hose. When I try to take the zirk fitting out, it is very tight - to the point I am afraid I will damage it trying to remove it. That gives me cause to believe it is tight for a reason.
Am I missing a drawing or better instructions? Maybe I need to heat it a bit to loosen? Thanks
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Last edited by rockwoodrv9 : 08-10-2017 at 09:16 AM. Reason: Had drawing page incorrect
Old 08-10-2017, 09:07 AM
BillL BillL is offline
Originally Posted by rockwoodrv9 View Post
Is there any better drawings than C4 about how to install the Cleveland brakes?
Yes, a heat gun or skillful application of a butane torch. They are just tight. Use loctite 567 on reassembly. Firmly restrain all the parts when removing.
I think you mean the bleed fitting? not zerk?? Right?? It is in an adapter. It is hollow with a tapered tip, easy to over tighten. Just the adapter is really tight.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
33/40 hrs
Aerobatics DONE!!
2017 Dues Paid
Old 08-10-2017, 09:15 AM
Correct Bill, it is the bleed fitting. The plan page is C2 rather than C4. The instructions are lacking as far as what I need to be assured I get them correct.
Thanks Bill.
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 08-10-2017, 09:50 AM
gasman gasman is online now
Use a pen propane torch on a clean (no brake fluid) unit. Heat to warm to the touch around the part to be removed. With the bleeder seated, remove as a unit.
VAF #897
2017 =VAF= Dues PAID
Old 08-10-2017, 12:51 PM
Larco Larco is offline
I'v never had to heat the cylinder to remove the fitting. Just used a GOOD box end wrench or 6 point socket and some grunt. However,
If you do heat the cylinder beware of the O ring that is inside on the piston. If you get the cylinder to hot you best replace the O ring. If you replace the O ring be sure to install the piston correctly. Long portion out.
Good luck
Old 08-10-2017, 05:30 PM
Or, just remove the piston/o-ring assy before applying heat...
Old 08-10-2017, 05:43 PM
I was able to get it out by taking it to my friends hangar and using his vice and my big box end wrench. Im getting real close to first engine start so I need my brakes working so I can drive around the airport!!
Thanks for the help.
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 08-10-2017, 09:08 PM
You might want to review your engine break in procedure before doing much driving around the airport. It would be a shame to glaze your cylinders??
Old 08-10-2017, 09:44 PM
I know. It just sounds fun!
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 08-10-2017, 11:18 PM
bruceh's Avatar
bruceh bruceh is offline
First engine run, be sure to restrain the airplane with some tie downs or chocks. The fresh brake pads and rotors won't have much grip to keep you in one place. After a couple of static engine runs, be careful the first time you want to taxi it around. You'll really need to stomp on the brakes a few times to bed them in.
I just changed my brake pads and it has taken a few hard braking's to get them to feel like they will slow you down.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2018 VAF donator
EAA Tech Counselor
