Old 08-08-2017, 11:22 AM
sritchie sritchie is offline
Default Do beringer nose wheels need any grease?
I know that the internal bearings are greased for life... but what about between the sides of the wheel and the bracket? I can't find anything online and would love some guidance!
Old 08-08-2017, 01:16 PM
Raymo's Avatar
Raymo Raymo is offline
I have the Anti-Splat version and, if I recall, lightly greased the axle and other bare metal parts.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 08-08-2017, 01:22 PM
BobTurner BobTurner is online now
??? There should be no contact between moving parts, except at the bearings.
Old 08-08-2017, 04:32 PM
That's correct, but the plans for the normal wheels still make a note about a light coating of grease between the outside non-spinning part of the bearing and the metal brace. I was assuming it had to do with a slight flex that would take place from heat or something.
Old 08-08-2017, 05:11 PM
If it's the area I'm thinking of (I'm not sure) the grease is just to help keep dust and grime out of the inside where the bearings are. There certainly should never be any contact of metal to metal.
