Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
View Poll Results: Ignition & Fuel system combination
Carburetor with one electronic ignition and one magneto 26 13.33%
Carburetor with two electronic ignition 24 12.31%
Fuel injection with one electronic ignition and one magneto 39 20.00%
Fuel injection with two electronic ignition 82 42.05%
No electronic ignition 24 12.31%
Voters: 195. You may not vote on this poll
Old 08-12-2017, 07:58 PM
humptybump's Avatar
I've got to give this a try ...
Originally Posted by Ironflight View Post
Two planes with dual P-Mags and fuel injection (one Bendix, one Airflow Performance). One plane with Slicks and a carb. One plane with dual P-Mags and a Carb.
RV-8 - Slicks and a carburetor
RV-6 - pMags and a carburetor
RV-3B - pMags and fuel injection
Tundra - pMags and fuel injection
It's a tough call on the assignments. The RV-3B is pretty certain but the Valkyrie has been around a while and Mikey has had numerous upgrades.
- Glen, ESVA
Old 08-12-2017, 08:15 PM
I went with 2 Pmags and a carb for my RV-3B. I chose the Pmags for ease of starting and efficient fuel burn.
My engine was delivered with a carb, and since I'm not planning on acro and don't plan to do inverted flight, that let me eliminate the inverted system and the fuel tank flop tube. On my certified plane, I've got an ARP carb ice detector and it finds ice in real time, so carb ice is not an issue. It's easily identified and controlled, and I have one for the RV-3B. Spruce sells them if that's a concern for you.
At my location, much of my flying is full throttle and leave it there until I descend for landing. Carbs aren't that bad at full throttle, I've read.
There you have it.
Old 08-12-2017, 09:42 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Close - you've got the six and eight reversed. Mikey is totally old school!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-13-2017, 11:01 AM
humptybump's Avatar
There's been a surge in polling data (161 results) from fuel injection 5:2 over carburetor. The carburetor install with single EI are 4:3 while the fuel injection installs are back up to 2:1 in favor of dual EI.
- Glen, ESVA
Old 08-15-2017, 08:12 AM
humptybump's Avatar
The poll has settled down (for the most part). I'd like to say "thanks" to everyone for participating and for the comments.
As of now, with 170 data points, it's 5:2 with fuel injection results more than double that of carburetor. The carburetor results are 6:5 with the single EI reporting ahead. The fuel injection results continue to hold at 2:1 in favor of dual EI.
- Glen, ESVA
Old 09-05-2017, 03:06 PM
Rbpilot Rbpilot is offline
I have replaced mags on my 0-290 with dual ignition (EFII). Injection to come later. Looks like FLYEFII has some new stuff out.
