Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
View Poll Results: Ignition & Fuel system combination
Carburetor with one electronic ignition and one magneto 26 13.33%
Carburetor with two electronic ignition 24 12.31%
Fuel injection with one electronic ignition and one magneto 39 20.00%
Fuel injection with two electronic ignition 82 42.05%
No electronic ignition 24 12.31%
Voters: 195. You may not vote on this poll
Old 08-07-2017, 07:14 AM
humptybump's Avatar
Default Electronic ignition and fuel systems (poll)
I've always been curious about the different combinations of fuel and ignition choices builder / owners make with their airplanes.
- Glen, ESVA
Old 08-07-2017, 07:23 AM
RV6_flyer's Avatar
One thing left off the poll would be dual electronic ignition and dual mags.
The LASAR and G3i systems are both dual electronic with dual mag backup.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-07-2017, 07:40 AM
Toobuilder's Avatar
Another choice which is gaining momentum is dual EFI and EI, such as the SDS system I'm installing.
As a fallback choice, my last 3 airplanes have been injected (Bendix) and dual EI.
Michael Robinson
______________
RV-8 - Flying
Old 08-08-2017, 04:00 AM
humptybump's Avatar
Interesting results thus far with 45 respondents.
- Glen, ESVA
Old 08-08-2017, 04:16 AM
rmartingt's Avatar
rmartingt rmartingt is offline
My choice is "other" - - full electronic fuel injection and ignition. (SDS).
RV-7ER - fuselage structure in work
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 08-09-2017, 10:40 AM
humptybump's Avatar
The sample set is not very big (81 data points at present) but the "trend over time" has been interesting to watch.
The general trend of responses has been 2:1 in favor of fuel injection vs carburetor. On the carburetor side, the responses have trended 2:1 in favor of a single EI while on the fuel injection side it has trended 2:1 in favor of dual EI.
- Glen, ESVA
Old 08-09-2017, 11:29 AM
Canadian_JOY Canadian_JOY is online now
A comment on your trend observations, Glen... It's been my observation that some of those who tend to operate from "less improved" airstrips and over less populated land often do their systems planning with independence in mind. The carb guys (I'm one) keep a mag because the combination of carb and impulse-coupled mag means one has the ability to get started while out in the boonies, long after some idiot left the master switch on and made hand propping a necessity. I've gone one step further by installing a manual priming system, again to avoid any dependence on the flow of electrons.
Old 08-09-2017, 11:54 AM
AttackPilot64 AttackPilot64 is offline
Default Poll
Dual EMAG PMAG with Fuel Injected engine plus GAMMI injectors = one smooth fuel efficient machine!
Old 08-09-2017, 12:05 PM
Bevan Bevan is offline
That's cool. I would like to know more about how you accomplished manual priming.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-10-2017, 05:51 AM
humptybump's Avatar
A comment on your trend observations ...
I don't think I'd ever be able to Devine the "why" in the data. With such a small sampling - currently a little over 100 out of thousands - there are definitely too many variables to make many scientific observations.
I also think there is a case for the "observer effect". While the poll is not quantum physics, the fact I commented about observed trends has changed those trends.
Currently, fuel injection is almost 3:1 compared to carburetors. The fuel injection responses have surged. The carburetor data is still trending 2:1 in favor of a single electronic ignition while fuel injected installations are narrowing a bit to 1.7:1 while still favoring fuel electronic ignition.
- Glen, ESVA
