Old 08-07-2017, 06:51 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Default Cabin Top Door Seal First Cuts
So I've been reading, downloading, more reading, looking at pictures etc trying to figure out where to start or not start on the door frame. Over the weekend I cut and fit the cabin top, still need to sand a couple of areas, but I didn't cut any of the door opening, or rear window frames for that matter. Now to my questions:
Just an Edit: I intend to install the mcmaster door seals.
1. Do I make a preliminary trim of the door frame to the Van's scribe lines, knowing you will cut more off later to fit the door seals?
Or
2. Do I cut nothing until I start fitting the doors?
Just curious how others approached this.
Lynn
RV-10 in Process
Old 08-07-2017, 06:58 AM
Auburntsts's Avatar
I simply followed the plans and cut how much (in this case to the scribe lines) and when it said to cut. Not trying to be sarcastic or anything, but generally I just relied on the plans and the build/assembly sequence laid out by Van's and for the most part things worked out just fine.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-07-2017, 07:00 AM
ERushing's Avatar
ERushing ERushing is offline
You might hear that you will end up cutting off more than you'd think. Personally, I cut off TOO much and had to rebuild things back up. So... I'd recommend the conservative approach - cut to Van's scribe line and then cut or sand back from there.
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 08-07-2017, 08:50 AM
My scribe lines were not accurate. I used them and cut off too much material. I recommend cutting to the dimensions referenced in the plans.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 08-07-2017, 10:07 AM
Lynnb's Avatar
I guess I might should have stated I'm cutting to use the mcmaster seals, not sure if that changes anyone's suggestions.
RV-10 in Process
Old 08-07-2017, 12:38 PM
AviatorJ AviatorJ is offline
I did the same... if I had to do it over again I would of waited until I had the doors mounted to cut the inside. Probably requires cutting a bit off when putting the doors on to get it to fit.
Justin
RV-10 Quickbuild 'Avionics and Interior'
http://operationrv10.blogspot.com/
Donated for 2018
Old 08-07-2017, 01:21 PM
Bill Boyd's Avatar
Default This is the best compromise
But if you're cutting for the McMaster seals, you will ultimately grind/sand for a 1/4" gap from the door, and that takes the curved portion of the door sill pretty much flat, parallel to the inside surface of the door. This results in a sharp edge, and necessitates building up the door sill edge to a consistent 1/4" thickness. Best done IMO as others have done, with pieces of McMaster seal used as a removable/reusable mold to hold flox in place on the door sill while it cures. Gives a perfect fit. Do other stuff while it cures. The leftover piece from a 25 foot order will do one doorway in about 5 cure sessions/nights. But be careful with it. Tears if handled roughly.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 08-07-2017, 01:28 PM
rocketman1988 rocketman1988 is online now
Default cut
I used Ivan K's measurements and they were almost perfect. Much easier if cabin top is not installed, and definitely easier to keep the dust out of the fuselage...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 08-07-2017, 04:26 PM
jeffwhip jeffwhip is offline
How can I find Ivan K's measurements? I'm getting ready to fit my cabin cover this week!
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - In the Works!
Old 08-07-2017, 06:23 PM
Default Umm...
I had the page bookmarked but it doesn't work any more. You might do a shout out and see if he still has his build log up...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
