Old 08-05-2017, 07:49 PM
n74846 n74846 is offline
Default Back-Up Radio Solutions?
My SL-40 died and is at Garmin for overhaul. My Icom A-6 is barely useful with the tower with the stock antenna. Has anyone found a successful solution to deal with the single radio failure scenarios? If you have added a switchbox or other jury rigged antenna, please describe. Thanks!
Steve at BCT
Flying a built ELSA
Old 08-05-2017, 08:25 PM
Cth6 Cth6 is offline
I can get about 5 miles out of mine in a high wing using the rubber duck. There is a high gain antenna that works in the aviation frequency that I have seen used before. Not sure how much more reach you get. With the low wing your best bet is probably a belly antenna or a t connector on your existing antenna with a pig tail.
CT
Dreaming about an RV
Orlando, Florida (FA83, X04, ORL)
Old 08-05-2017, 08:45 PM
DHeal DHeal is offline
It is my understanding that you cannot simply install a T-connector in the antenna line. Either install a separate belly antenna with a dedicated cable to use with your hand-held or install a special switch that selects one radio or the other for your one antenna -- King Avionics used to sell such a switch.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 650+ hours (as of July 2018)!
VAF donation through June 2019.
Old 08-05-2017, 08:53 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default ANTENNA SWITCHBOX
ANTENNA SWITCHBOX
https://www.aircraftspruce.com/catal...mswitchbox.php
Carl N.
Arlington, WA (KAWO)
RV-8, 340 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 08-05-2017, 08:56 PM
I had a spare Microair 760 from another project so I installed it in the panel as comm 2. It has a separate antenna I mounted on top of the fuselage and the audio-in is wired through my intercom with independent jacks as a backup.
Old 08-05-2017, 09:24 PM
NYTOM NYTOM is offline
I've always used a separate external antenna with a coiled antenna wire near the seat cushion that can easily be connected to my Icom handheld. Also used a Icom headset adapter and was good to go. Has come in handy a couple of times when I developed trouble with my panel mount com.
Tom Norwood
Classic "Short Tail Six" A Model N822PM (Res)
99% done, 1% to go! Oh so close!
Old 08-05-2017, 09:53 PM
DonFromTX's Avatar
This makes the most sense to me. I would not fly without a handheld,
and this gizmo allows you to use the aircraft com antenna with the handheld.
I have it installed on my plane.
Originally Posted by RV8JD View Post
Retired US Army Officer
Old 08-05-2017, 10:18 PM
Poor man's solution: bring the antenna coax to a panel BNC. Bring the radio coax to another nearby BNC. Jumper the two BNCs with 8" of coax. If main com fails unplug the jumper from the radio, plug into the handheld.
Old 08-06-2017, 10:05 PM
The only time in 31 years of flying that my radios went out was, of course, the day I forgot my handheld. The tower guys loved it because they never get to use the light gun.
Old 08-10-2017, 10:48 AM
Thanks to all for their input. Still trying to figure out how to route either the switchbox, or add another separate antenna for the handheld.
Interestingly I searched the web regarding the Icom A-6 headset adapter problems I've been having and found an interesting thread. While I have not had time to check it out in the plane, apparently the adapter DOES NOT kill the handheld mic in lieu of the headset mic. Hence if I do not talk into the handheld instead of the headset mic, I cannot be heard; which is exactly what I am experiencing. A bizarre quirk of the Icom headset adapter, but might be my big problem. The solution, according to the thread (and quoted from Icom Support) is you must use the auxiliary PPT switch they sell, which plugs into the third plug on the adapter. Only then does the headset mic engage. Who knew?
Steve at BCT
Flying a built ELSA
