Old 08-03-2017, 03:11 AM
Neal Trombley Neal Trombley is offline
Default Purchased wing kit 85% done info please
I was sent great pics and feel comfortable with the purchase.
I spoke with vans on transferring serial numbers etc all is good on that front.
Issue now is getting the fuselage SB version from vans.
I keep reading that there is a center piece that has to line up or work with the wings? I'm confused on this.
When I do order the fuselage is there anything I need to do or request from vans?
I really wanted to SB my wings but the savings was to great to pass up.
As usual thank you in advance.
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 08-03-2017, 05:34 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default Should be Included
The fuselage center section that you are referring to actually ships with the wing kit and the matching spars. The wing kit also includes the fuselage longerons, so be sure those are included as well.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2017 Dues paid (July 2017)
Old 08-03-2017, 07:17 AM
cczarnik cczarnik is offline
Serial #'s may not match the center section with the wings. At least they didn't in my -7 shipped from Vans. But you should have the center and the longerons with the wing as mentioned before.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 08-03-2017, 07:32 AM
airguy's Avatar
airguy airguy is offline
According to the older project builders this used to be a quite critical dimension, that the wing spars would have to be matched by serial to the center section - but in 2008 when I was building my wings I was one of a handful of builders that got wing spars that had the flanges incorrectly bent, and ultimately had them replaced. http://websites.expercraft.com/airgu...y&log_id=30034
During conversations with The Mothership they informed me that my concerns about the close match on the spars to the center section were no longer a major problem, the current machining process was adequate to mix/match the serials without an issue. They shipped a new pair of main wing spars and sure enough when it came time to mount the wings, no problems were encountered.
Perhaps Scott can throw some historical clarification on that.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-03-2017, 07:55 PM
bret's Avatar
bret bret is offline
Bought quick build wings and built a SB fuse and bought a center section somewhere else, you can mix and match no worries.
2018 gladly supported
Old 08-03-2017, 09:08 PM
mfleming's Avatar
mfleming mfleming is offline
Yes, I agree with the consensus that the center section does not have to match.
I ordered standard wing kit and a quick build fuselage.
When the fuselage arrived, it was a clunker .
Returned it to Van's and picked up a new fuselage...
No concerns about matching spars and center section.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated 2017
