Old 08-02-2017, 09:30 AM
LeoKenner's Avatar
LeoKenner LeoKenner is offline
My goal is not to squeeze out any more performance, and I certainly don't want to exceed Vne. My goal is to not have to have the compromise of climb or cruse performance but to get both.
Old 08-02-2017, 09:50 AM
Mel's Avatar
Mel Mel is offline
Most RVs have a speed ratio between top speed and stall approaching 4:1.
The speed range of the RV-12 is closer to 2.5:1. You will see very little improvement with a constant speed prop within this speed range.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-02-2017, 10:06 AM
Mel,
I don't read his goal as expanding the speed range. I read it as expanding the *performance* envelope. With a controllable prop, he gets to keep the top end speed, possibly with better fuel efficiency, and get significant improvements in climb performance.
To OP: There are several electric prop options that are purpose-built for the 912/914 series engines. Most are European or Pacific region products, since we lead the world here in the USA in technology.....
Charlie
Old 08-02-2017, 10:09 AM
EAGLE BOB EAGLE BOB is offline
Have you considered a ground adjustable prop. If so, Whirl Wind has them and very reasonably priced.
Old 08-02-2017, 10:10 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by rv7charlie View Post
Mel,
I didn't mean to imply that he is looking to expand the speed range. I was simply stating that a C/S prop will produce little improvement over F/P on an aircraft within the speed range of the RV-12.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-02-2017, 10:47 AM
LeoKenner's Avatar
Mel,
Charlie
Thanks Charlie. I know the Virus SW uses an electric CS propeller. I believe it is an MT... I will start digging.
Old 08-02-2017, 04:34 PM
rongawer's Avatar
rongawer rongawer is offline
Airmaster has CS props that will fit Rotax. I provided a PN earlier that will fit the UL engines.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
