Old 08-01-2017, 08:45 PM
LeoKenner's Avatar
LeoKenner LeoKenner is offline
Default Constant speed prop for RV-12 Expermental?
Has anyone done a constant speed propeller for an Experimental RV-12?
I would much rather go that route than the ground settable option.
I know in the US it is simpler to register as LSA, but in Canada the RV-12 will be an experimental either way so I don't have to worry about any of the LSA restrictions.
Old 08-01-2017, 08:58 PM
rongawer's Avatar
rongawer rongawer is offline
I didn't do it, but I do go through an evaluation and found one that would be a good fit. An Airmaster AP431CTF-WWR66U. The downside is the USD $9850 retail price, but you can get it for around $8800 from Ray L. at Kaolin Aviation, who is a US dealer.
For me, the price wasn't worth the potential performance gain.
Ron Gawer
- RV12, N975G, Phase 1 testing
- BE58, N1975G, stimulating the economy one flight at a time.
Old 08-01-2017, 09:18 PM
rv9builder rv9builder is offline
Any idea what the performance gain would be in cruise and climb?
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 08-01-2017, 09:23 PM
rongawer's Avatar
Determine the top speed of your RV-12 with the prop pitched for cruise, and then the best climb rate with it pitched for climb. That's the performance of the constant speed prop.
Ron Gawer
Old 08-01-2017, 09:39 PM
Thanks, Ron. Since most RV-12s have a fixed-pitch prop that is a compromise, I wonder if anyone has tried to fly one in "max cruise" or "max climb" mode? I wonder what the gain would be at each extreme end of the range—maybe an extra 5 knots in cruise and a few hundred feet per minute in climb? Who knows!
RV-12iS Fuselage
RV-9A Project: Sold
Old 08-01-2017, 10:28 PM
Driftdown Driftdown is offline
If you alter an RV-12 with a constant speed prop, in the USA, wouldn't that take the airplane out of the LSA category, as per FAR's?
Old 08-01-2017, 11:42 PM
You are correct that it would no longer qualify as an LSA. However, it could be registered as E/A-B. But with a constant-speed prop, it could not be flown by a Sport Pilot.
RV-12iS Fuselage
RV-9A Project: Sold
Old 08-01-2017, 11:48 PM
redbaron redbaron is offline
Smile constant speed prop
in the US it would in eab , the add at is a neg. speed fairings might be a better plan.
Old 08-02-2017, 05:01 AM
joedallas's Avatar
joedallas joedallas is offline
Default Top Speed ?
Also remember the 12 was designed as a light sport and cruising much faster for long period of time will add stress on the airframe that the 12 was not designed for.
My View
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-02-2017, 07:38 AM
DaleB's Avatar
DaleB DaleB is offline
CS prop or no, you're not going to get much more speed out of an RV-12 without an engine swap. You might squeeze 125 kt out of it... but it's not like you're going to exceed Vne or anything.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
