Old 07-30-2017, 11:29 PM
Eztroller Eztroller is offline
Default When to prime
I am on page one step 7 of the emp, and was wondering when/what I should prime. If I just follow the directions, will that be sufficient? I plan on priming. I read ahead several pages and they state, to prime parts but arent specific as to what to prime.
Little confused already....
Old 07-31-2017, 04:45 AM
mturnerb mturnerb is offline
Get ready for a very long discussion. You may want to look through some of the "primer wars" threads.
A few points:
1. Vans QB wings/fuse use "wash primer" that seems to hold up well in the area where you live. I have a set of QB wings on order and will be depending on their experience in this area.
2. Some people elect to prime only where plans specify - mostly steel and non-alclad parts. Many of these airframes are flying pretty much corrosion-free after 1-2 decades or more. Advantages - build time, weight
3. Some folks prime everything. Even though I live in Florida (humid and potential salt air exposure), my approach is to prime internal parts like ribs, skins where they meet other parts like ribs/stiffeners, and bottom skins fully since water might collect there. (I want primer to cover any area where water/salt/gunk might collect). I also prime any part that's not alclad (and of course I prime any part called out in plans - most recently gear braces in Section 29). Most Florida airplanes from certified companies are doing OK after decades with very little internal priming from the factory - my approach is to try to balance weight/time/airframe longevity.
4. Primers vary from the "wash primer" used by Van's to self-etching "rattle can" primers (I use SEM mostly, with some Eastwood epoxy primer in certain areas like bottom skin overlap), to spray-on two part epoxy primers (AKZO seems to be most popular).
One more suggestion - look at build sites/blogs ("Carl and Rafael", Tim Olson for example) for ideas on priming and parts prep as well as general guidance when you can't figure out what the plans are trying to tell you...
Turner Billingsley
RV-14A Fuselage in progress
Old 07-31-2017, 06:21 AM
Reflex Reflex is offline
EZ,
Good question, I got a little confused there too. On one hand it tells you to rivet, on the other you know you've got to prime first....if you're priming.
I cleco'd the entire assembly up to page 06-04. After Step 3 on that page, the plans say to "Disassemble all parts and deburr". The next line says "Prime parts as applicable if desired". I deburred and primed everything that I had assembled at this point.
Regarding what to prime, it's up to you, but pretty much the inside of the entire structure is going to get primed. The hinges are powder coated so some builders scuff and prime, others leave as is.
As I recall, I primed in two sections 1) The assembly described above 2) The skin after final drilling and deburring.
As you progress, you'll be surprised how much of the structure can be cleco'd together before disassembly and priming.
Hope that helps.
Fred
Dues Paid for 2018
RV-14
Working on Empennage
Old 07-31-2017, 07:22 AM
BillL BillL is offline
Here are some questions (as I understand them) to ponder regarding primers:
Will the there be a top coat?
Will the top coat lift the primer?
What primers are proven effective with all the RV aluminum alloys?
Does my selected primer pass the salt spray, and weather exposure testing?
How do I want to apply the primer?
Is my selected primer available for the method I want?
Is only one primer required for the whole plane?
Answer these questions and you can select a good primer.
Now - as a community - what corrosion problems have been seen in the RV fleet? Cessna? If there are no issues, then, is a primer needed? Can an inappropriate primer accelerate filiform corrosion?
The answers are a lot longer than the questions, thus primer wars. All is within VAF.
Bill
Op Lims in hand 12-7-17
Prep for 1st flight underway.
2017 Dues Paid
Old 07-31-2017, 09:58 PM
Wow! Thanks for the clarification and very thorough responses. Hopefully i can return the favor someday.
Old 07-31-2017, 11:22 PM
wirejock's Avatar
wirejock wirejock is offline
Default Prep
Don't stop you're research on primer alone. Preparation is as or more important than the primer choice.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-01-2017, 12:42 PM
unitink72 unitink72 is offline
Default prime before/after dimpling
Only thing I might add. On the RV-10 the instructions tell you when to prime, but they always say to do it after dimpling. My prep process includes maroon scotch-brite. Scrubbing down around and in all those dimples is a big PITA, so I always dimple after priming.
Should mention that i use AKZO, and it sticks just fine even in/on the dimple.
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2017 Dues Paid
