Old 07-28-2017, 09:19 AM
findane findane is offline
Default Center Rib has no rivets?
The F7108A center rib in the upper forward fuselage is shipped with no pre-drilled holes in the flange that sits up against the firewall. Some of the plans show pre-drilled holes in the flange, others do not. Is there any reason why the center rib should not be match drilled and riveted to the firewall?
Closed Thread
