Old 07-27-2017, 12:07 PM
SJordan SJordan is offline
Default Need stick travel numbers.
Hi guys,
Can someone please measure the travel of the control stick on a -4. Maybe just hold a tape measure at the top of the front stick and give me total travel number for elevator and ailerons. Also how tall your stick is from the floor.
I don't have my wings or tail on yet and trying to figure some stuff out.
Shawn
Old 07-28-2017, 05:36 AM
Shawn,
I can measure mine when I go to my hangar next time, but there are a few factors to keep in mind. Your a long way from setting the final position, which has variables created by the torque tube adjustment, center console/panel height variations and rear stick/front seat back clearance. On my -4, I installed a vertical center panel from the tunnel up to the bottom of the panel , but displaced forward a few inches. The stick must travel well forward of the panel bottom, and clearance for your hand must be considered. If you are not installing a center panel, you have no worries about forward restrictions. Also, the "neutral" position of the stick can be set FWD/AFT by adjusting the torque tubes. I would recommend keeping the sticks as long as possible until you sit in the seat and find the length best suited for you. I used a tubing cutter to do my final cut after the seats were done and I was installing the grips. Full left/right travel will likely be against your leg and can't be adjusted unless the geometry is changed. I know this sounds like a lot of bla bla bla, but you will soon understand it all. I have lots of pictures from the build and final product if you need.
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 07-29-2017, 08:24 AM
Originally Posted by fixnflyguy View Post
Shawn,
Hi Bill,
Thanks for reply and great advice. You are absolutely right that I'm far away from setting my controls up, though I was trying to get my floorboards made and trying to figure out how big the stick opening are going to need to be. My -4 though is so far from standard with the dash 2" forward, roll bar 2" back, seat back bottom 4" back. My front stick I did leave tall but have put a 3" S bend in it to get it back to where I think my lap will be, the rear stick is going to require the same big S bend to clear the front seat back or maybe no stick at all. I think at this point I will just leave my floorboards as is and move forward and it won't take more than a morning down the line to trim the opening to clear stick travel if need be. I actually think I will be fine and the opening are big enough. I probably have been watching too many aerobatic videos and think my -4 stick will move way more than it actually does.
Thanks Again for the advice
Shawn
