Old 07-24-2017, 09:41 PM
VA Maule VA Maule is offline
Default Main Spar nut plates
Did a search but no joy , however I'm quite sure someone has had this same question. Main Spar W-706 between inboard most rib W-710 & W-711 are 3 pre-punched nut plate hole sets in the main spar. Can be seen on DWG 11 A view #4. I can't find any call out for which nut plate go hear if any go hear at all?
What am I missing? Or are they for some other model that share this component ?
The Best Government is less Government
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage underway
Old 07-24-2017, 11:42 PM
N546RV's Avatar
N546RV N546RV is offline
Those are for tank attach nutplates. For all of the other tank attach brackets, the nutplates live on the bracket and the bolts are inserted from behind the spar, but for the inboardmost bracket, the nutplates are on the spar and the bolts are inserted from the forward side. The nutplates used there should be the same as those used for the other attach brackets, if memory serves.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 07-30-2017, 08:25 AM
resrob66 resrob66 is offline
Check Drawing 16A, Detail A for the callout.
Robert
RV-8 Showplanes Fastback
Emp. & Wings Done
Fuselage up to QB stage
Old 07-30-2017, 07:44 PM
Default Got it
Got it found,thanks to you both for the assistance.
Lancer 235(partner)
