Old 07-24-2017, 11:35 AM
Wunderon's Avatar
Wunderon Wunderon is offline
Default Hoist by canopy bow?
I'd like to put it on the gear and most convenient would be to hoist the fuselage by the canopy bow using an engine hoist. Seems plenty robust and would be easier solo than blocking under the spar box. Think that's ok?
Thanks!
dave
Dave Grimmer
RV8 firewall forward
EAA 84
paid 2018
Old 07-24-2017, 12:22 PM
DennisRhodes DennisRhodes is offline
I would not risk a broken canopy for an easy location to lift. Just use the motor hoist on the motor mount and avoid an expensive canopy repair.
DRRhodes
2018 VAF dues paid
RV9 N908DR
Old 07-24-2017, 12:24 PM
Ah, no canopy or engine , might work OK then.
DRRhodes
2018 VAF dues paid
RV9 N908DR
Old 07-24-2017, 12:45 PM
Wunderon's Avatar
Think I'll put the motor mount on and use that.
Dave Grimmer
EAA 84
paid 2018
Old 07-24-2017, 01:19 PM
This is one of those instances where it's a good idea to sit back and think for a bit. What was the canopy bow designed to do? In what direction is it designed to take loads, and at what point in the flight profile?
I'm no aero engineer however I think most of the experts here will likely agree the canopy bow is intended to take some aero loads from the windshield and then the ultimate end-of-life crush load to protect occupants. This would lead one to believe its mounting is not designed to withstand an upward pulling load associated with hoisting the aircraft.
Again, just a guess, and sometimes we get away with doing things we shouldn't. Still, risking damage just seems like a low odds game.
Old 07-24-2017, 01:37 PM
akarmy's Avatar
akarmy akarmy is offline
That's the best choice, and what I used with an engine hoist to move it around.
I did have the canoe upside down with the gear in the air to line everything up. For much of the construction I had a swivel stand mounted to the motor mount locations which allows the fuselage to be rotated as needed.
Re-arranged the garage by Andy Karmy, on Flickr
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Nov 2017 Paid
Old 07-24-2017, 02:56 PM
If you don't have the motor hung, throw a 2" nylon strap around a convenient bulkhead. Use a spreader bar at the top, if it makes you more comfortable. If it's just the fuselage (no wings), you should just about be able to lift it by hand; the hoist is just for safety.
Old 07-24-2017, 03:18 PM
wirejock's Avatar
wirejock wirejock is offline
Default Lift
What's wrong with a 2"x6" spanning the center section spar carry through and a floor jack?
I built a frame for my 2 ton aluminum racing jack specifically for this so I can lift the fuse.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-24-2017, 03:35 PM
Larry,
I've used similar techniques, after the motor was hung, without the gear mounted. But if he needs to go high enough to mount the gear, I know my floor jack won't get the job done. :-)
Old 07-24-2017, 05:35 PM
Wunderon's Avatar
I think that is a good idea and considered it, but the center section is wired with cables, so too tight for me.
I need to get the motor mount on anyway. Kind of at the point where really need the engine to continue, so thought I would work on the wheel pants and fairings while waiting on it.
Thanks all for the great suggestions. What a resource VAF is.
dave
Dave Grimmer
EAA 84
paid 2018
