Old 07-22-2017, 05:49 AM
Remyswing's Avatar
Remyswing Remyswing is offline
Default Corroded aileron brackets
My 6 years old RV-8 ( Aluminium Lady) shows some paint strip due to corrosion on steel ailerons bracket, certainly due to proximity of chemical plant acid environnement , and I guess due to lack of durable paint applied in factory
Rudder bracket are also impacted and need to be treated
Do any one of you already find such discrepancy?
( I iiil show pictures as far I find how to...)
Remy " Remyswing
Quality controler
AC & Hel mechanic
Servon, Paris, FRANCE
RV-8 " Aluminum Lady"
began on May 2009
First flight on 09 July 2011
Old 07-22-2017, 06:39 AM
brad walton brad walton is offline
After 365 hours, I just replaced the nuts, bolts and washers on my aileron brackets due to corrosion which made them look bad, but probably still safe. My brackets are protected by Imron paint and still look fine.
Old 07-22-2017, 07:33 AM
flion's Avatar
flion flion is offline
I powder-coated the brackets on my -6A and no problems after 10 years.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
EAA Technical Counselor #5357
