Old 07-21-2017, 10:29 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by Jesse View Post
The normal/acceptable oil consumption rate is below 5 Hours per quart to upwards of 20.
More specifically it is given as a maximum in Section 3 of the Lycoming Engine Operating Manual.
It varies by power setting - for a O-360-A model -
Full rating at 2700 rpm - 0.8 qts per hour
Performance cruise (75%) - 0.45 qts per hour
Economy cruise (65%) - 0.39 qts per hour
The economy cruise number would give almost 10 qts used in a 25 hr oil change period. I would be concerned if my engines got close to that..
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-21-2017, 10:55 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default From Lycoming Service Instruction No. 1427C
NOTE:
The following formula is used to calculate the maximum allowable oil consumption limits for all Lycoming aircraft engines.
0.006 x BHP x 4 7.4 = Qt./Hr.
For an O/IO-540 260 HP at 75% cruise the limit is .8432 quarts per hour.
TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 07-21-2017, 01:32 PM
bret's Avatar
bret bret is offline
With that formula, would you run out of gas or oil first
2018 gladly supported
Old 07-21-2017, 02:08 PM
N427EF N427EF is offline
Don't know anyone who would be happy with that kind of oil consumption
but that is what it says in the service manual.
Jesse described a "normal range" for you, mine runs about 14hours per quart.
I guess I am in the normal range.
I would be concerned if all of a sudden my consumption went from current levels to say 5 hours per quart.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 07-21-2017, 02:15 PM
rv7charlie rv7charlie is online now
See my earlier post about oil pan size.
Old 08-01-2017, 02:53 PM
MauleDriver's Avatar
MauleDriver MauleDriver is offline
Originally Posted by ReidVaitor View Post
I asked my engine builder years ago, his response- let the oil go down until it stops losing oil. 6qts is were it stops and loses very little below that mark. I have added more (7qts) on new changes and it keeps the same temps and throws it out most oil quickly than stabilizes at 6.
My temps are 200F +/- 10F at 6 qts in warmer climates
That is my experience and this is what I do...
I put 7 qts in at change time - it registers as 6.5 or so.
At about 40 hours I'll be below 6 qts. If it hits 5.5qts, I add some. Otherwise at 50 hours I change it.
As a by-product, it seems to keep my oil temps above the minimum. I fly out of NC, nuff said.
Old 08-01-2017, 08:21 PM
tim2542 tim2542 is offline
Just another opinion on this subject, but I'll let mine (O-360) burn down to the 5 qt. level, it seems to stabilize there. I won't let it get much lower than that, but I'd be comfortable on a cross country at the level or lower if an oil change is due soon.
It uses ~Qt/15 hrs. so that helps with my comfort doing that.
5qts is well over Lycomings min.
Tim Andres
