Old 07-20-2017, 02:50 PM
bob888 bob888 is offline
Default Oil Level
Is there a consensus re acceptable oil level to minimize venting through the breather yet maintain a safe margin in the engine?
Old 07-20-2017, 03:49 PM
Jesse's Avatar
Jesse Jesse is offline
6.5-8qts. I know some people who add a half quart or full quart when it gets to there preferred level in this range. Most -10's seem to blow out quickly over 8.5qts.
Edit: ...but I doubt you'll get much consensus on this.
352-427-0285
jesse@saintaviation.com
Old 07-20-2017, 04:06 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Oil level
At oil and filter change I will add 9 qts. of oil. After first engine run that will show at about 8.5 on the dip stick. Fly the airplane until the oil dip stick shows 7.5-8 and then add a quart. (typically 10-15 hrs.) Anything over 9 qts. on the dip stick is too much and will get blow out the breather and show up as on the belly.
I believe the book says the engine will run safely down to something close to 4 qts. but I would not test that....
RV-10 Quick Build
SN # 40838 (C-GMDV)
First flight June 28, 2010. Now 1065 hours of flight time.
Home field is Waterloo Regional Airport (CYKF) Ontario Canada,
2018 VAF dues paid.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 07-20-2017, 05:47 PM
An O-320 is supposed to have a 2 quart minimum...
Most a/c oil sumps were spec'd to keep from running out of oil before the fuel ran out.
Old 07-20-2017, 06:28 PM
Auburntsts's Avatar
I keep mine between 7.5 and 9 Qts.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 07-20-2017, 06:40 PM
Toobuilder's Avatar
I add 8 at oil change (full), and add again when it hits 6.
Michael Robinson
______________
RV-8 - Flying
Old 07-20-2017, 07:03 PM
vernon smith's Avatar
vernon smith vernon smith is offline
I'm curious, have no experience to go on. What is a "normal" hourly oil consumption rate at say half way to OH time? One qt every 5 hours, every 10 hours?
Old 07-20-2017, 09:23 PM
ReidVaitor ReidVaitor is offline
Default oil level
I asked my engine builder years ago, his response- let the oil go down until it stops losing oil. 6qts is were it stops and loses very little below that mark. I have added more (7qts) on new changes and it keeps the same temps and throws it out most oil quickly than stabilizes at 6.
My temps are 200F +/- 10F at 6 qts in warmer climates
Old 07-20-2017, 09:46 PM
I don't think there is a 'normal'. But if you haven't seen the oil consumption numbers that Lyc considers acceptable, you're probably in for a shock. (Hint: oil pan capacity; see my previous post.)
Charlie
Old 07-21-2017, 09:45 AM
Jesse's Avatar
The normal/acceptable oil consumption rate is below 5 Hours per quart to upwards of 20.
352-427-0285
