Old 08-11-2017, 11:20 AM
auburnaviator auburnaviator is offline
Here's what was emailed to me fellas. Hope this helps everyone out.
Here is a list and some photos of the stuff I am selling.I bought it in order to try to convince a local school they should build a 12. No luck there, so it needs to be sold.
Here is a copy of the correspondence from the guy I bought it from, even
some photos if you please. I would like to get $1000 for the kit plus shipping (it is a
heavy box) Heckuva deal for someone I think. Let me know if you have any
questions.
“A complete tool kit for building an RV-12. I bought this used in great
condition a few years back, and have not used anything. Common sense got the
best of me and building an airplane will not be in my (near) future plans,
but hopefully they will fit into yours! I'd like to keep this as a complete
kit. We can discuss shipping options, or meet up if possible. I'm happy to
comply with any anti-scamming criteria you'd like to line up!”
https://drive.google.com/file/d/0B9t...ew?usp=sharing
https://goo.gl/photos/twzAUBDLpg1N9wiNA
AVERY TOOLS RV-12 TOOL KIT ITEMS
PART # DESCRIPTION QTY
3/32 DDS 3/32" DIMPLE DIE w/SMALL DIAM FEMALE
1/8 DDS 1/8" DIMPLE DIE SET
#8 DDS #8 DIMPLE DIE SET
1621 1/8" FLUSH SET
1627 1/2" FLUSH SET
1602 SP 1/8"X 1/2" CUPPED SET
1017 1/8" CLECOS (325 PCS.)
1016 3/32" CLECOS (50 PCS.)
1012 1/2"X1 SIDE GRIPS (5 PCS.)
1014 1/2"X1/2" SIDE GRIPS (5 PCS.)
200 CLECO PLIERS
40 #40 COBALT DRILLS (4 PCS)
30 #30 COBALT DRILLS (4 PCS)
19 #19 COBALT DRILLS (2 PCS)
#21 DRILL (1 PC)
12 #12 COBALT DRILLS (2 PCS)
52 #52 COBALT DRILLS (4 PCS)
12X30 #30 X 12" EXTENSION DRILL
1/4 1/4" COBALT DRILL (1 PC)
11 #11 COBALT DRILL
16 #16 COBALT DRILL (2 PCS)
3 # 3 COBALT DRILLS (2 PCS)
5/16 5/16 COBALT DRILL 1 EACH
11/32 11/32 COBALT DRILL 1 EACH
1003 BOELUBE - TUBE
575 HAND SEAMER
1046 SPEED DEBURRING TOOL
22022 ROYAL MULTI-BURR TOOL
1052 #30 C'SINK CUTTER
1051 #40 C'SINK CUTTER
1053 #27 C'SINK CUTTER
1054 #20 C'SINK CUTTER
1055 #12 C'SINK CUTTER
30-120 SPECIAL #30 X 120 CUTTER
19360 MICRO-STOP C'SINK CAGE
7891 PNEUMATIC POP RIVET PULLER
P26A TIGHT SPACE POP RIVETER
4910 ADJUSTABLE TORQUE WRENCH
UBX3 UNIBIT #3 1/4" to 3/4"
6510L OFFSET SNIPS – LEFT
6510R OFFSET SNIPS – RIGHT
212 PARKER ROLO-FLAIR FLARING
470-FM TRIPLE HEADED BENDER
7447 S/B GEN. PURPOSE HAND PADS
4510 SMALL BLOCK FOR DIES
6-32 6-32 TAP
3/8-16 3/8-16 TAP
3/8-24 3/8-24 TAP
1/4-28 1/4-28 TAP
72758 6 PC. 4" SMOOTH FILE SET
AVERY TOOLS ADDITIONAL ITEMS
11071 1/8” PLASTIC DRILL 1 EA
UBX1 UNIBIT STEP DRILL #1 1 EA
11076 #40 PLEXIGLASS DRILL 1 EA
11077 #27 PLEXIGLASS DRILL 1 EA
15357 1⁄4” UNDERSIZE REAMER (0.2490) 1 EA
21/64 21/64 COBALT DRILL 1 EA
CLEAVELAND AIRCRAFT TOOL ITEMS
HAND OPERATED RIVET SQUEEZER 1 EA
SSF1 #1 FLAT SQZ. SET 1/8”X1/2” 1 EA
SSF4 #4 FLAT SQZ. SET 1/4”X3/8” 1 EA
SSF8 #8 FLAT SQZ. SET 1/2”X3/8” 1 EA
SSC4 1/8” SQUEEZER CUP SET 1 EA
DBS40 DRILL STOP #40 1 EA
DBS30 DRILL STOP #30 1 EA
RLG1 ONE PIECE RIVET GAUGE 1 EA
EF60 EDGE FORMING TOOL 1 EA
AIRCRAFT TOOL SUPPLY COMPANY ITEMS
G480 DOUBLE DEBURRING TOOL 1 EA
FP21 DELUXE FLUTING PLIERS 1 EA
STEIN AIR, INC. ITEMS
SAT-018 MOLEX / Open Barreled Pin Crimper 1 EA
SAT-004 4 way indent Crimper 1 EA
SAT-023 Insertion/Removal Tool for D-Sub pins 1 EA
SAT-005 Automatic Wire Stripper 1 EA
SAT-006 Flush Cutters 1 EA
Old 08-11-2017, 11:52 AM
Auburntsts's Avatar
Ahh an Avery kit -- Well that explains why listing just the vender wouldn't have helped since Avery is out of business.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-11-2017, 12:17 PM
charger81 charger81 is offline
Default Two?
Two straight posts from guys who like the color auburn?
Old 08-11-2017, 12:26 PM
Auburntsts's Avatar
Burnt Orange actually!
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 08-11-2017, 12:41 PM
Talking
Now you're talking!
Hook 'em!
Old 08-11-2017, 01:39 PM
Burnt orange, War **** eagle!
Old 08-11-2017, 02:52 PM
DonFromTX's Avatar
Thanks for posting that, I had assumed it was too long and would be rejected.
This should answer lots of questions.
AF1 (was RV12) EAB Air Force One, SN 461, N461DG VIKING/HONDA ENGINE POWERED! AND N756TS ROTAX POWERED
Retired US Army Officer
http://www.mykitlog.com/users/index....X&project=1903
