Old 07-21-2017, 08:11 AM
Pittsartist Pittsartist is offline
When I first started flying my RV-6 I was surprised to find that applying FULL aileron produces buffeting from the Ailerons and that at best the roll rate is only the same as at about 80% deflection - maybe even less.
My preferred way of measuring this is an in cockpit gopro or similar - preferably showing the stick position as well if possible - just fly 2 continuous same direction rolls and time the video.
Old 07-21-2017, 04:54 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is online now
Originally Posted by ALMARTON View Post
I got a owners manual... and I service it on a authorized shop. I got hold of some plans also.
Good deal. I meant to say earlier that you can get the complete set of plans AND construction manual from Van's on a DVD for (IIRC) $10.00.
The advantage of that is you can put them on a memory stick or your phone or tablet and have them with you all the time, so that in the event of a problem away from home, you have quite a bit of info to assist you in solving the problem.
I did the same with all of my schematics, avionics manuals, engine documentation, etc.
Old 07-21-2017, 05:08 PM
RV8JD's Avatar
RV8JD RV8JD is offline
They come on a USB stick nowadays:
http://www.vansaircraft.com/cgi-bin/...oduct=fd_plans
Carl N.
Arlington, WA (KAWO)
RV-8, 340 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 07-21-2017, 05:25 PM
I am curious why you started another new discussion on the exact same subject as you did a couple weeks ago...... you never responded in that thread with info regarding what you found after checking things that were suggested.......
Scott McDaniels
Hubbard, Oregon
Old 07-21-2017, 06:44 PM
ALMARTON ALMARTON is offline
Which thread you refer to?
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497– 72’’, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
