Old 07-24-2017, 01:45 PM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by grubbat View Post
Curious to know how much you will loose if you ditch the huge wheel pants but leave the gear leg fairings and intersection fairings but add hub caps on the wheels. Of course you would also have to ditch the long Van's axle nut and get a standard castle nut to fit under the hub caps.
They are called "pressure recovery" pants for a reason.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 07-27-2017, 07:43 PM
grubbat's Avatar
grubbat grubbat is offline
Default Hub caps vs huge wheel pants
To answer my own question, the hub caps cost me 1.5kts over the "pressure recovery" wheel pants. For me, the ease to check air pressure and also use the tire as a step to clean the windscreen is well worth that whopping 1.5kts.
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1946 Piper Cub - in process......
Old 07-27-2017, 08:31 PM
I think you haven't done enough testing to actually know........
I agree the leg fairings are worth the biggest speed increase, but the wheel pants are good for more than 1.5 Kts
Scott McDaniels
Hubbard, Oregon
Old 07-27-2017, 08:53 PM
grubbat's Avatar
Default Agree
That's probably true Scott. Maybe my wheel pants were not constructed tight to the wheels to begin with or maybe some other variation somewhere else in the process. The hub caps are painfully simple. Over the next several months I'll keep a watch on the data and see if I can detect a change.
Craig
RV-3 Sold
RV-6a Sold
