Old 07-18-2017, 06:59 PM
klh1507 klh1507 is offline
Default Newbie questions: Match drill holes vs enlarge holes
Working on the horizontal stabilizer. Instructions for the spars and doublers said to "match drill" holes. For the ribs on the spars, the instructions say enlarge holes. Do these terms mean the same thing or do I disassemble all the clecoed parts and drill them separately? If drilled while clecoed together, do I need a longer drill bit? (Seems I wouldn't want to push the rib out of the way with the drill.
Old 07-18-2017, 07:08 PM
cczarnik cczarnik is offline
Welcome to VAF!!!
Drill them together. Go ahead and invest in a 12" #30 and #40. They'll come in handy.
Personally I like to use reamers where I can instead of drill bits. Holes come out much cleaner and more precise. There is a debate on them- you might read the forums on pros/cons.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2017
Old 07-18-2017, 07:12 PM
Also you might partially disassemble to match drill. E.g. Remove the forward ribs and match drill the aft ribs. Then remove the aft ribs and match drill the forward through the at-size spar holes. That should get you going without waiting for longer bits. But they will come in handy.
When match drilling sheets, use the reflectivity of the sheet to sight when the bit is perfectly straight. Learned this tip at Osh last year at the cleavland booth-
Chuck
Old 07-20-2017, 02:44 PM
Default Thanks...
I ordered long bits and also disassembled parts to drill. Simple solutions like that are what I have to learn. Thanks to both of you.
Old 07-20-2017, 03:09 PM
izzybear's Avatar
izzybear izzybear is offline
Default To answer the second part of the question...
Kevin,
Match drilling and enlarging are not the same thing. Match drilling is using the pre-punched hole in one skin/part to make a "matching" hole in another skin/part that you will rivet.
Final drilling is when you have holes in the two skins that already line up - but they are pre-punched a tad small and need to be drilled to the correct size. Final drilling also removes the small burrs made by the punch.
Enlarging is when you have a pre-punched hole that is in the correct place, but is maybe a 3/32" or 1/8" hole and needs to be drilled to 3/16" for a bolt to fit thru. That saves you from having to measure where the hole needs to be - you just have to drill the hole up to size.
Hope that helps... keep working
Jim
RV-8 N223TG (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2017
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
