Old 07-18-2017, 09:11 AM
rapid_ascent rapid_ascent is offline
Default F-757 Plate Fitting Details (Slider)
Late last night I fitted my F-757 plate on the right side. All went well. The one detail I'm unsure about is that at the forward side of the curved cutout it extends slightly inboard, maybe 1/16", from the edge of slot in the trim piece. There are no details in the instructions or a detailed enough view in the drawings to tell exactly how it should fit.
I'm assuming this probably doesn't matter, but I was just going to adjust the radius slightly so that the two pieces align. I'm not sure of the function of this piece other than being a gusset so I wanted to check before trimming some off.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 07-18-2017, 11:17 AM
Raymo's Avatar
Raymo Raymo is offline
Detail B on drawing 42 shows that it blends into the slot. I don't recall if I had to trim mine or not but it is flush at the fwd end.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 07-18-2017, 01:22 PM
Ok that's what I figured. i just wasn't sure why there was even a notch there.
Ray Tonks
2018 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
