Old 07-18-2017, 10:03 AM
rgbewley rgbewley is offline
Default Is Your Engine Affected?
Chances are that most of the affected engines are factory or Thunderbolt built engines shipped from November 2016 - February 2017.
If you engine was overhauled/repaired in the field prior to 11/2016, you will not be affected.
From my shop if your engine was overhauled/repaired between 11/2016 and 2/2017, you most likely will not be affected as the shop we use for these repairs almost exclusively uses Superior rod bushings, except for parts under EASA regulations. But, if you have a question, feel free to drop me an email.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
Old 07-18-2017, 10:07 AM
SkyFlorida's Avatar
SkyFlorida SkyFlorida is offline
Mine was shipped July 2016 and it's affected.
Michael Albert
Fuse.
Old 07-18-2017, 10:11 AM
Default Bigger tent
Lyc is gonna need a bigger tent at the show!
John S
Fuselage started
Old 07-18-2017, 10:13 AM
jwilbur jwilbur is offline
Was hoping to do first flight this weekend. .... My engine is on the list.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 07-18-2017, 10:27 AM
az_gila's Avatar
az_gila az_gila is online now
Smile
Originally Posted by airguy View Post
Can you replace the con-rods and bearings without splitting the case? Doesn't look practical to me but I've never opened an engine either. This looks like a pretty invasive fix to a nearly new engine.
Connecting rods and con-rod bearings yes, main bearings no...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-18-2017, 10:29 AM
F1R F1R is offline
Default IO -390 ?
I don't see any IO -390 engines on the SB List. I hope this is correct. I thought they were the same cylinders as the 580 that are on the list. Perhaps the rods are unique to the 390 and the list is correct.
Old 07-18-2017, 10:51 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Legalese
A quote from the SB
"YOU MUST COMPLETE THE “REQUIRED ACTION” IN THIS SERVICE BULLETIN. IF YOU DO NOT COMPLETE THE “REQUIRED ACTION” IN THIS SERVICE BULLETIN, AND THE CONNECTING ROD BUSHING MOVES OUT OF PLACE, THE CONNECTING ROD CAN FAIL AND CAUSE UN-COMMANDED STRUCTURAL ENGINE FAILURE."
I love that term, "Un-Commanded Structural Engine Failure", as opposed to, I guess, a "Commanded Structural Engine Failure".
I am wiring the cockpit right now. I am thinking of putting in a switch with the notation of "Commanded Structural Engine Failure", just in case I need to kill the engine at some point. Just to be safe, I will make it a guarded switch.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 07-18-2017, 10:54 AM
Electrogunner Electrogunner is offline
Default Rod bushings
Just checked my overhauled parts from aircraft specialties that were done in febuary. They used superior rod bushings SL 13923A so mine were not effected. Only lycoming parts affected. This will be quite expense for some folks, mainly lycoming.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Finishing and FWF is ongoing
Old 07-18-2017, 11:25 AM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by Steve Ashby View Post
A quote from the SB
Sort of like "Rapid Unscheduled Disassembly"
Old 07-18-2017, 12:03 PM
airguy's Avatar
airguy airguy is offline
A quote from the SB
You could put it right next to the "Chem Trail" switch.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
