Old 07-14-2017, 02:11 PM
cczarnik cczarnik is offline
Default Dimpling Aileron Leading Edges for counterweight
Working with the leading edge and the counterweight tube.. Have the 120 dies / countersink for CS4 rivets...
1- With that skin wrapping around the tube, I don't think I can dimple the skin with a "flat" dimple die set on such a tight radius. So my plan is to countersink the tube, and then use the tube as the "female" die, and hit the skin with the male dimple die in the rivet gun. Any gotchas with this approach?
2- Since these rivets are on a tight outside radius, should I over countersink a few thou to get the rivets to flush to the skin? I'm assuming that laterally (along the length of the aileron) they'll flush no problem, but worried about them protruding vertically on the top / bottom as the skin rolls away?
Any tips before I dive in? Am I overthinking this step? Thx-
Chuck
7a emp complete, wings underway
VAF Dues paid - 2017
Old 07-14-2017, 02:56 PM
David Paule David Paule is online now
1. That's how I did it on my RV-3B.
2. You can form the rivet heads to the curve on the top and bottom.
It appears to have worked fine, but then again, my plane's not flying yet. What do I know?
RV-3B Skinning the fuselage
Old 07-14-2017, 03:05 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Don't overthink this...
"Machine countersink the holes in the counterbalance pipe. The countersink need not be 120 to match that of the rivet heads. The .020 skin and the aluminum blind rivet will deform sufficiently to contour to a 100 countersunk hole."
Just do a normal countersink. You can grind off one side of a dimple die to make it fit inside the radius. Then just set the pulled rivets and move one.
It's not even visible once the aileron is installed.
Old 07-14-2017, 09:45 PM
wirejock's Avatar
wirejock wirejock is offline
Default Same here
Make that two. I did the same.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
