Old 07-14-2017, 08:53 PM
pczar3's Avatar
pczar3 pczar3 is offline
Thumbs up Thanks for all the replies
It is interesting that I measured from the front of the firewall to the bulkhead with this twist and it is within a 32nd of an inch compared to the other side. It must be the bulkhead itself that has the slight twist. I'll probably go with the shims and as they say "build on". Thanks again for all the help and suggestions.
Paul
Paul
N694BP reserved
RV-6A Very Slow Build!
Old 07-14-2017, 09:19 PM
painless painless is offline
Agree with getting your stab clamped in place and aligned to see where you are at. May end up not being an issue. Properly placed shim(s) would be a solution if need be.
Hang in there and stick with it. Us 6A builders/flyers need to stick together!
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 07-15-2017, 09:50 AM
JonJay's Avatar
JonJay JonJay is offline
Paul
The bulkhead may be square flange to flange but it is common in these vintage kits for the web to have a slight buldge or roundness. In other words, the web may not be flat. My guess is that is what is causing the twist.
You might be able to manipulate this into shape by relieving the slot in the deck. I would find what is causing this problem before I just jumped to the conclusion that a shim is your salvation.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-15-2017, 11:21 AM
acam37's Avatar
acam37 acam37 is offline
I bought a second hand RV-4 kit and one of the rear bulkheads was riveted in the wrong location. I wound up with a 5/16" gap on the vertical stabilizer front spar attach point. Vans said that a 5/16" spacer in that area was perfectly acceptable.
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) under construction
KOCH Nacogdoches
Old 07-15-2017, 03:49 PM
JonJay's Avatar
That is common procedure for VS. However, I have never seen it on a HS. Again, I would want to know why it is the way it is before I contemplated a fix. As it has been mentioned, shimming an out of alignment "twist" is very different than shimming to a parallel or square surface.
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-16-2017, 08:29 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Van's has the final say in resolving this but I would bet that if you measured from tip to nose on most RV-6s, you would find that the measurements are not the same.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 07-16-2017, 10:37 AM
JonJay's Avatar
I wouldn't bet against you!
My main bulkhead is 1/4" off as it came from the factory as a QB. Hence, I have one wing neutral and one with 1/2" sweep. Doesn't affect anything.
Paul, if you can resolve the twist in the bar to allow the HS Spar to be flush to it, all should be good.
At the top of that bulkhead there is a 3/4 x 3/4 x 1/8 angle. The bars rivet to the bulkhead and to that angle. Both bars should be flush to the face of that angle. Perhaps the F-116 Bulkhead assembly isn't flush to that angle on that one side. As mentioned, this could be caused by the web not being flat, but as I look at the plans, that bulkhead web doesn't have much meat at the top where it attaches to the angle. It gets cut out to allow the push rod to pass through.
I would make sure that bar is indeed riveted to the angle and is flush to it. Should be able to see with a mirror.
Call Vans when you figure out what is going on. I am just not a fan of shimming out problems until you know what the cause is. You might discover more things that need attention and the empennage group is one area you just don't mess with.
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-16-2017, 01:24 PM
sblack sblack is offline
Only 5/16" ? Lucky Mine was half an inch!
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 07-16-2017, 07:38 PM
pczar3's Avatar
Smile Here is what is going on... finally
Well I spent the better part of the weekend measuring and doing more head scratching. When all was said and done, I can see the control stop angle is set at a very slight angle towards the front of the plane. By slight, I mean about a sixteenth of an inch on the starboard side. While standing and looking I noticed the stab mounting bar looked a bit strange. I put a straight edge on that and realized I must have hit it at some point because is was not true. I trued everything up, put the HS on the plane and did the measurements to the middle of the fuselage up front. All it will take is about .020 on the pilot side and everything will be lined up. HS tips are on the button and everything else looks good. I think I'll bolt things up and get ready for the VS mount.
Thanks again to this great group for all the help and encouragement.
Paul
Paul
N694BP reserved
