Old 07-13-2017, 07:05 PM
pczar3's Avatar
pczar3 pczar3 is offline
Unhappy How can I deal with this Horiz. Stab
Well I am finally at the point of mounting my horizontal stab on my VERY slow build 6A. After wrestling with the stab for a while I decided to check the rear spar mounting bars. One, the blurry image, is the good side. The square is flat against it and the other leg falls right on the center line (picture 1). The other side is offset towards the back of the plane 0.125 on the outside and one sixteenth on the inside. Has anyone else run into this and what was the fix? Thanks in advance.
Here's the good one:
This is the problem!
I hope the pictures show up now. I see them when I look at the page.
Any help appreciated!
Paul
Paul
N694BP reserved
RV-6A Very Slow Build!
Last edited by pczar3 : 07-14-2017 at 06:38 AM. Reason: trying to post pictures from google photo
Old 07-13-2017, 08:00 PM
painless painless is offline
Pictures aren't being displayed
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 07-14-2017, 06:02 AM
pczar3's Avatar
Unhappy Back to the drawing board trying to insert pictures
Well I guess I was done in by google photos. I'll try again!
Paul
Paul
N694BP reserved
Old 07-14-2017, 06:50 AM
219PB 219PB is offline
I would ask Vans. If they allowed a shim that would be an easy fix. But I suspect that they would not due to the bending stresses in that joint. It should be in pure tension under load.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
Old 07-14-2017, 07:05 AM
BillL BillL is offline
Photos work now, but not sure what the design tolerances are, so you need Scott McDaniels to address this one. Or some of the sages here.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
33/40 hrs
Aerobatics DONE!!
2017 Dues Paid
Old 07-14-2017, 09:07 AM
JonJay's Avatar
JonJay JonJay is offline
Clamp your HS into position onto the tabs, with the .125 spacer installed under the HS Spar per plans. Find the fuselage center line and then measure from the fuselage center line, as far forward as you can, like the firewall or seat back brace, back to each HS tip. Compare those measurements. I believe this process is documented in the manual. This will tell you if that bulkhead is indeed square or not. You might get lucky as variances in the HS might offset those of the bulkhead. You might find you have less of an issue than you think.
Also, examine the bulkhead and see why that bar is twisted.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-14-2017, 09:24 AM
rv6builder's Avatar
rv6builder rv6builder is offline
Mine were like that too, but that stab only needed very slight re-alignment. Remember even half an inch of movement at the tip is a tiny movement at the root. A call to Van's definatley a good idea if you have any concerns though!
Alex
Alex Doughty
Canadian ATPL
RV6- The engine runs...
2017 Dues paid up
Old 07-14-2017, 11:08 AM
sblack sblack is offline
You might need some custom angled shims. Do you know a local home shop machinist? Easy for them to make. If not PM me. Above all, don't panic. My vertical fwd spar missed its pickup on the hstab by 1/2"! I was able to work around that. These older kits are not as easy to build. Creative shimming required.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 07-14-2017, 11:14 AM
az_gila's Avatar
az_gila az_gila is online now
I think a shim would be called for and be acceptable, and I also bet that this was probably not that uncommon on the not pre-punched -6 fuselages.
A call to Vans should be made to confirm, but as a previous poster mentioned install the horizontal first with clamps and align per the plans so that you have an exact measurement of the thickness of any shims needed.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-14-2017, 12:55 PM
However you shim it, make sure the head of the bolt and the nut are on parallel planes. So if the stab is one one plane and the mounting tab is at a 3 deg angle to it with a 3 deg shim, make sure you have a shim under the head of the nut so that you are not putting a bending load on the bolt when you tighten it.
Scott Black
VAF dues 2016
