Old 07-12-2017, 07:37 AM
jwilbur jwilbur is offline
Originally Posted by sbalmos View Post
Just had to defuel also last week in order to deal with leaks. So once you have all this fuel out into 5-gallon cans... what do you use to refuel in one gallon increments to recalibrate?
I poured from the 5 gallon cans into a calibrated 2 gallon can (I had to do 2 gallon pours) then from the 2 gallon into the tank.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 07-12-2017, 07:39 AM
sbalmos's Avatar
sbalmos sbalmos is online now
That was my hope to do also. I'm just drawing a bit of a blank on where to source a calibrated 1 or 2 gallon can. Googling around at the moment.
Scott Balmos
Butler County Airport, KHAO
RV-9A Slider N112SB
Started 1/12/12, Airworthy 6/4/18, First Flight 7/4/18
Build Time - 6.5yrs
IO-320 w/EFII and Catto 3-blade
Beringer brakes/wheels/tires
Dual G3X Touch (Stein's bankrupted me!)
In Phase 1
=/\= 2018 Donation Paid =/\=
Old 07-12-2017, 07:43 AM
I went to Tractor Supply and bought a 2 gallon can (which has a 2 gallon 8 ounce mark on it). Then I calibrated it to 2 gallons with a nice black mark around the outside. I calibrated by weight. 1 gallon of AVGAS weighs 6.01 lbs.
Phase II - 11/2017
Pink slip - 7/2017
RV-10 Build Log
Old 07-12-2017, 07:46 AM
az_gila's Avatar
az_gila az_gila is online now
Smile
Don't rely on the markings on a 2 gallon red plastic fuel container from the auto parts store.
I did my initial, partial calibration that way and found the molded in marking was about 10% off.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-12-2017, 07:49 AM
sbalmos's Avatar
Gil - exactly my fear. I /know/ those markings aren't right.
Joe - Thanks for the idea about calibration by weight. That sounds more probable for me to do. And yes, I'll zero-out the weight of the can itself beforehand.
Rob - Heh. That might be a while when you have a full 36 gallons sitting around in cans and you're still a few months away from first flight. Might as well just sell it off to the others on the field and hope the FBO doesn't notice.
Thanks for letting me hijack the thread!
Scott Balmos
RV-9A Slider N112SB
Build Time - 6.5yrs
In Phase 1
Old 07-12-2017, 08:50 AM
flion's Avatar
flion flion is offline
Originally Posted by g zero View Post
5 gallon Homer Buckets from Home Depot , if you go to the paint dept they also have a calibrated gallon pail
NO!!! Not only is that large opening inviting trouble of all kinds, but some plastic does not tolerate gasoline. Don't count on the cheap 'pickle-bucket' cans being consistent. The five-gallon jerry cans specifically manufactured for fuel are not prohibitively expensive, and the plastic ones are pretty safe to use. I got four red ones for my avgas and labelled them 100LL, plus two blue diesel cans for the Jet-A that goes in my kerosene shop heater. 10 years and no leaky cans or other problems.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 07-12-2017, 11:00 AM
Flyin'Bryan's Avatar
Flyin'Bryan Flyin'Bryan is offline
Default From the movie Die Hard with a Vengeance:
"Next to the brief case you will find a 3 gallon jug and a 5 gallon jug. Fill the 5 gallon jug with EXACTLY 4 gallons of water and place it on the scale. if you fail the bomb will go off. You have 5 minutes to comply...."
Sorry guys, I just couldn't resist a little humor around this seriously very important and informative topic! Do it safely and have a great day!
Bryan Raley
http://bryansrv8project.blogspot.com/
Building RV8
EAA Chapter 301
CFII/MEI, ATP
SportAir Workshop Graduate x 4: Sheet Metal, RV Building, Electrical, and Composite classes.
Tail Wheel Endorsement Completed
Empennage done, Wings in progress, N462AK reserved.
Old 07-12-2017, 11:41 AM
sbalmos's Avatar
Default The Holy Gas Can of Airportdom?
"Three shall be the number thou shalt count, and the number of the counting shall be three. Four shalt thou not count, neither count thou two, excepting that thou then proceed to three. Five is right out."
Scott Balmos
RV-9A Slider N112SB
Build Time - 6.5yrs
In Phase 1
Old 07-12-2017, 03:41 PM
moosepileit moosepileit is offline
Fill 5. Dump 3 into 3.
Dump 3 on ground.
Repeat.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 07-13-2017, 02:20 PM
g zero g zero is offline
Default Fuel drain
Yes , HDPE , look it up , same plastic used in Fuel Tanks .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
