Old 07-02-2017, 03:41 PM
Bart Bart is offline
Default Plane Power 12 Volt 60 Amp - field CB pop
I blew the 5 amp field CB coming back into the pattern today. Had zero problems with this system for last 8 years. Brushes look good and in tolerance, no noise spinning the motor, wires look good, 5 AMP CB feels good, event has not repeated itself...anyone else have experience? Do these just **** out after a 8 years or should I be looking at something else?
Old 07-02-2017, 08:07 PM
climberrn climberrn is offline
Does it have "crowbar" OV protection?
Was told that a poor connection in the field switch, specifically the split Cessna rocker switches can cause the field line to pop. Check alternator connections and consider changing the master switch.
Joel
N626JA
RV-7A at CXP
Flying!
Old 07-02-2017, 08:18 PM
Thanks Joel, just spent the last 4 hours checking wires, master, field plug, etc. All the wires and switches seem good. I'll call the plane power folks in the morning. I have a feeling I may have hit the useful life of my unit.
Tankerpilot75 Tankerpilot75 is offline
Default Had this also happen
I also had my 5 amp field circuit breaker for my 60 amp plane power alternator pop once. Discussed this with my A&P/IA and we reset it. It hasn't repeated itself and it's been almost a year. Sometimes xxxx happens for no apparent reason.
If it was me I'd reset it and wait to see if it repeats. If it does, investigate further.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, Garmin 340, 335, Dual 430s, Stratux hard wired to WS, Dynon D10A (backup EFIS)
Retired - Living the dream - And going broke!
Old 08-11-2017, 01:56 PM
thinkn9a thinkn9a is offline
Default One free reset (even if it is against training, usual, std approach)
The dwg with attached documentation, for AL 12-EI60/B alternator (60 amp) states
If the breaker trips
1. Reset 5 amp circuit breaker and CONTINUE operations
2. If 5 amp breaker trips AGAIN, land as soon as possible and investigate cause
Tech rep at Osh says the electronics are sensitive and they are having more nuisance trips due to quick transients, .... reset breaker
P.s. Documention on Hartzell / plane power states their INTERNALLY regulated alternators have built in crowbar over voltage protection
Ps ps - anyone have a part number for the brushes ?
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
