Old 06-16-2017, 06:21 AM
todehnal todehnal is offline
Default Skyview Screen Shutter Flutter
I call it "Shutter Flutter" because it reminds me of some old film strip movies where your eye catches the frames advance which gave them a flutter effect. At cruise I can detect a very slight screen flutter on my Skyview. It is more noticeable in the background on the primary display area, and it appears to be cycling somewhere in the 8 Hz area. Interestingly, I don't see it at idle. I have watched some of the in flight training videos that Kirk from Dynon made and noted that there was no flutter, of course he is not flying an RV-12. So, I thought that it may be unique to my installation, but I just viewed a youtube video of a Skyview display in a flying RV-12 and I noticed similar flutter. It is not a serious distraction, but I sure would like to identify the cause. Now I am thinking that this may be common to the RV-12. Is anyone else experiencing this, or do I have a unique problem?
Thanks.........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 06-16-2017, 06:57 AM
tomkk's Avatar
tomkk tomkk is offline
I've got almost 300 hrs on my -12 and I haven't noticed anything like that. I'll specifically look for it next time out ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 06-16-2017, 08:14 AM
Jesse's Avatar
Jesse Jesse is offline
I have never seen this, even in an RV-12 with Skyview. I wonder if it is voltage/installation related.
352-427-0285
jesse@saintaviation.com
Old 06-16-2017, 08:54 AM
bkervaski's Avatar
Just going to throw this out there .. random thought .. are you perhaps viewing through polarized sunglasses? They can cause the effect you are describing on some displays.
Reserved: N196
Progress: Firewall Forward
Old 06-16-2017, 10:05 AM
DaleB's Avatar
DaleB DaleB is offline
How's your interior painted? Could it be a strobing effect caused by sunlight either passing through or reflecting off of your prop, then reflecting off the interior paint?
Alternatively, it's not too much of a stretch to imagine a vibration issue with the backlight driver board.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 06-16-2017, 01:13 PM
This is a very subtle shutter effect. It is not even particularly annoying, other than concern as to what is causing it. I only detect it by fixing my view on the horizon line on the display, but it is there. I don't wear polarized glasses,and it is not a reflection from anything that I can detect. On my next flight I will see if I can determine more accurately the RPM range where it becomes apparent and report back. As always I greatly appreciate the input from you guys.
Tom
Old 06-16-2017, 01:28 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
FWIW I have seen a few unusual screen behaviours on the D-100 series that were caused by bad grounds to EMS sensors. However, they were isolated to specific section of the screen. What you described sound more like what you would see on your computer screen at home if you set the refresh rate below 60mhz (which can be very annoying).
If not already, I would check with Dynon. Unless it's a know software or hardware issue they will most likely tell you to check all connections.
Let us know what you find out.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 06-16-2017, 04:24 PM
alexe alexe is offline
To see if its noise on the incoming power, just turn off the master and let the Dynon run off of the backup battery. If the problem goes away, you know where to look next. If not, call Dynon for further ideas.
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 06-16-2017, 05:46 PM
n233va n233va is offline
Angry
Do Not turn master switch off with engine running unless a real emergency. See RV12 POH.
Date: 06/14/16 Revision:5
GENERAL
This section covers the recommended procedures to follow during emergency and adverse flight conditions. As it is not possible to define every type of emergency that may occur, it is the pilot’s responsibility to use sound judgment based on personal experience and knowledge of the aircraft to determine the best course of action.
It is considered mandatory that the pilot be familiar with this entire manual, in particular, the “Emergency Procedures” section prior to flight.
W ARNING
Do not turn off the Master switch with the engine running
except in an EMERGENCY situation.
Running the engine with the Master Switch off may damage the voltage regulato
Old 06-16-2017, 10:39 PM
OK then, pull the fuse feeding the Dynon.
Alex Erdelyi
