Old 06-07-2017, 12:56 PM
bernsbm bernsbm is offline
Default Dynamic prop balance
Hi All,
I'm looking for a shop in the southeast Wisconsin/northern Illinois area that can do quality dynamic prop balancing, preferably with Rotax experience. Any/all suggestions appreciated.
Barry
Barry Bernstein
N12BB RV12 flying since Oct 2016
2018 dues happily paid
Old 06-07-2017, 03:36 PM
springer springer is offline
Originally Posted by bernsbm View Post
Hi All,
Barry
Not SE WI but at the Cumberland Airport, WI the Cirrus dealer does it. I have not used them.
http://www.aviationvibes.com/vibrati...nd-mitigation/
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 06-07-2017, 07:15 PM
I'm curious... why do you feel the need to balance your prop? I set the pitch on my blades with Van's sheetmetal gage and I'm very pleased with the flight performance and engine/prop smoothness especially at cruise RPM.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 06-07-2017, 07:24 PM
Walt's Avatar
Walt Walt is offline
I have balanced quite a few 12's and every one benefited significantly. It is also a recommended procedure by both Rotax and Sensenich.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 06-07-2017, 09:59 PM
12vaitor 12vaitor is offline
Just finished balancing mine this weekend. Started out at 0.21 ips, was very happy with the final result after adding 11 grams of weight.
John Salak
RV-12 N896HS
Old 06-07-2017, 10:07 PM
Slane Slane is offline
Default Prop balance
Where and how did you attach the weight?
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
VAF paid 2018
Old 06-07-2017, 10:17 PM
Driftdown Driftdown is offline
x2 . . . . . .
Old 06-07-2017, 10:45 PM
Mark C. Mark C. is offline
Call Poplar Grove Airport, IL they have a guy that balances props. About $250. Mark C.
Old 06-08-2017, 12:15 PM
I started out by adding weights (washers) under the spinner attachment screws at the clocking angle indicated by the DynaVibe display. Took four runs to get the ips down to 0.01-0.02. I used a precision scale to weigh the washers and converted the inch/gram value based on the spinner screw hole location to the spinner plate location I drilled (radius decrease by 1/2" so weight value increased). I added a #8 screw with two nuts and a spacer weight at the new hole in the spinner backing plate. The total weight of the screw, nuts, washers, and spacer weight were 11g. I was fortunate that the clocking angle was almost exactly on a spinner attachment screw.
The factory listed weight difference between the two Sensenich blades is 6 grams (1204g and 1198g), so the weight location is actually near the root of the lighter blade. Not sure how that compares with other RV-12s, but it may be an indicator of the improvement you can expect from dynamic balancing.
John Salak
RV-12 N896HS
Old 08-06-2017, 05:48 PM
dtw_rv6 dtw_rv6 is offline
I spent Saturday morning trying to balance my RV6 / Superior IO360 / Sensinich setup with the same Dynavibe model shown in the photo above. However after 8 runs trying to dial in on the best balance, I discovered that none of the results were repeatable on subsequent runs! I removed all weights and headed home to ponder what could be going on.
Has anyone else found repeatability to be a problem? I was able to get down to about 0.12ips, but a 2nd trial with no change yielded 0.38ips!
Originally my setup was showing 0.42ips. The last run of the day was back to no weights, and I was getting 0.57ips. Not sure what is going on. We had similar results on a different engine and airframe earlier that week.
Don
