Old 06-06-2017, 11:48 PM
ReidVaitor ReidVaitor is offline
Default very cheap- DIY
Originally Posted by Sandrews View Post
What are you guys using for nav/strobe lights in the stock wingtip location? Is there a more economical version than the $700+ kit that Vans sells? I have Landing/taxing lights in the stock location, so just looking for the navs.
Its old but works great- the LEDs today are brighter and less expensive but 6 years later they still all work flawlessly. I think it was $20 per side for the whole project
http://www.vansairforce.com/communit...ht=pete+howell
As for the strobes- using old police strobes- from strobes n more- here is an example http://www.strobesnmore.com/Surface-...ained-LED.html - I dont have these but if I was installing today probably would go this route.
Pascal
Old 06-08-2017, 03:00 PM
SFSA1's Avatar
SFSA1 SFSA1 is offline
Hey guys here is another option from SF Sport Aviation:
http://sfsportaviation.com/index.php...ry&path=24_101
Check out our Facebook page for more pictures:
https://www.facebook.com/sfsportaviation/
Eladio Gomez
561-396-9211
eladio@sfsportaviation.com
www.sfsportaviation.com
Old 07-03-2017, 04:27 PM
EDIT: Hmmm....No idea why this ended up here; it was a response to the thread about a diode on the back of an alternator.....
If you're right, and it is a transorb, then you need to ask yourself why it's blown up. If the alternator went into overvoltage, it would have blown. If the battery was ever hooked up backward, it would have blown.
Note that if installed in a properly configured system (definitely *not* the case in that picture), the transorb (or a zener diode, for that matter) would not blow; the fuse/breaker that's (should be) upstream would blow/trip.
See the data sheet on the Spruce link for proper configuration. It isn't intended to protect the B lead circuit of the alternator, and cannot actually protect anything wired as shown in your pic.
Old 07-04-2017, 05:48 PM
Aiki_Aviator's Avatar
Aiki_Aviator Aiki_Aviator is offline
Default FLYLEDS
Yep another A++ for FLYLEDS.
I have had them for near on 3 years and brilliant.
And support.......second to none. Any issues, Paul is always there to give a hand.
Andrew Long
#41055
RV10: Happy little Vegemite :-)
Feb 2015: Now fully functional..... and quick
http://www.ozrv10.com
Old 07-05-2017, 08:11 AM
civengpe civengpe is offline
Originally Posted by WrightsRV7 View Post
Very happy with the AVEO nav/strobe performance and at the time, meeting the FAA night requirements was an important decision factor for me. Not sure what the AVEO lifetime warranty is worth, hope I never have to find out.... Having all the aircraft lights on and watching only a few amps total draw...kudos to the inventor of LED technology!!
My posistrobe failed and they replaced it no questions asked!
Shannon
Flying September 2015
Old 08-03-2017, 08:19 PM
Sandrews Sandrews is offline
Ended up going with Aeroleds from Vans. After checking out many at OSH I liked their install the best.
