Old 06-02-2017, 09:07 AM
ppilotmike's Avatar
Default +1 Aveo
I have all Aveo stuff, including Herc 30s for my landing/taxi lights in the leading edge. I should look like a 747 on approach.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 06-02-2017, 09:12 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default FlyLEDS
Just in process of assembling the FlyLEDS from PAul and so far the customer support has been great! Missed the skinny board on order form and Paul helped me get them.
Still assembling and so far so good, however, he needs to update the photos in instructions.
Way less expensive option and i have heard great reports on brightness.
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 06-02-2017, 11:20 AM
TimO TimO is offline
A question on the FlyLEDs...
They offer a tail LED. Is that a tail strobe, tail position light, or a combo light like what you would buy from Whelen. I built my own wingtip system and it was very affordable, but the tail strobe I had to buy. Some day I want to remove the strobe pack in my RV-10 and stick a combo LED in the tail. If FlyLEDs is a combo, I'd consider it, although I'm a bit concerned about water/weather as opposed to a fully sealed unit like the Whelen that I put on the -14...that is a very nice light.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 175+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 06-03-2017, 09:20 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
G'day Tim
We offer a stand-alone strobe that operates as a combo position light and strobe light. We also add custom flash patterns to this model for you.
I now coat these units with a protective lacquer, so moisture shouldn't be an issue (nor has it been yet!).
If it fails I'll replace it!
The standard model tail light shown on our website is designed to go with the wing kit. It also functions as a combo light under the control of the central control board, so that the tail light flashes in pattern with the wing boards.
Paul McVitty
Flyleds.com
VAF advertiser
Old 06-03-2017, 09:35 PM
Very nice. I may just have to try that out later this year. It's definitely a lot more affordable than going Whelen, so if it's noise free and reliable it should be a real good deal.
Tim Olson - CFI
Old 06-03-2017, 11:37 PM
rdamazio's Avatar
rdamazio rdamazio is offline
Another +1 for Aveo - got their Ziptips, they are very bright and look great (caveat: I'm not flying yet).
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 06-04-2017, 10:37 AM
majuro15's Avatar
majuro15 majuro15 is offline
Yup, Aveo has a few different options with the ZipTips being the coolest by far.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Fuselage under construction
N1017H Reserved
EAA #: 1106970
2018 VAF Dues Paid!
Old 06-04-2017, 01:18 PM
Carl Froehlich's Avatar
For $3K they better be way cool!! That is a lot of avgas.
I've been running AEROLED nav/strobes for five years on the RV-10 and will use them again on they new RV-8 project. Landing lights will be a RUN-D 40W 3" spot LED Cube Pod in each wingtip. This is a well made product and two are just $160.
Old 06-04-2017, 01:55 PM
Electrogunner Electrogunner is offline
Default Aveo
The OP wanted economical, so I would say AVEO is out. Way out.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Finishing and FWF is ongoing
Old 06-05-2017, 07:13 PM
ty1295 ty1295 is offline
Took a very quick video tonight as I tested the Flyleds on 12V for the first time. The camera is bright, but I promise in person you can't look directly at the strobes.
https://youtu.be/LeG35VOrt24
Obviously I am a piece or 2 from flying, but at least the position lights are working now.
Jeff Scott
Proud to have flown with P. Wagstaff and some odd Russian.
RV9A #91247/#91434
