Old 04-02-2017, 10:53 PM
JDA_BTR JDA_BTR is offline
Default Compass in Panel
For the ultimate in redundancy in bad times, a compass is useful. Are there any that are suitable for mounting in the panel? I suppose it would be easy enough to put one on the glare shield (like my Arrow has), but would be way cooler in the panel....
N1463 seems a good number....
Old 04-03-2017, 07:48 AM
brad walton brad walton is offline
I put one in the panel of my RV8. It was accurate in all directions... until I closed the canopy
Old 04-03-2017, 07:50 AM
mturnerb mturnerb is offline
I think the biggest challenge with a panel mounted compass is magnetic and induction interference from other equipment behind the panel. I have a compass in my current airplane (Bonanza) that swings a bit when equipment under it in the panel is turned on - and that is about 12-15" away.
The new Garmin G5 HSI with remote magnetometer (battery backup) would be a pretty reliable "compass" IMHO.
Turner Billingsley
RV-14A Fuselage in progress
Old 04-03-2017, 08:11 AM
bhester's Avatar
bhester bhester is offline
Thumbs up Some places work, some don't
I have had mine in two different locations in my panel and it has worked. When I was redesigning my panel a couple years ago, I used plaxiglass to trail fit everything, including the compass to make sure everything worked and fit properly. I used this compass and have heard that the cheaper Falcon model does not work well, but I've never used one of those. While trial fitting I did find that when I turn the key to start the plane the compass swings but comes right back to the correct setting and works correctly.
http://www.aircraftspruce.com/catalo...d_compass3.php
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2017 VAF donator - alot better than any magazine subscription
Old 04-03-2017, 08:37 AM
Default + 1 for PAI-700
We too have one on top of our clear shield and it works very well. Our compass card shows about 4 or 5* at the most for an off-set or correction.
These units are certified and I have seen them work in the panel as well, they fit a standard small hole for panel mount. We keep it up there just for peace of mind and if we wish to cross the ADIZ and a red coat wishes to check us over closely. Never has happened but we like to stay safe and out in front of the interpretation of the rules if we can.
Your call, hope this helps, Yours, R.E.A. III #80888
Old 04-03-2017, 11:35 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
I have one in my panel, but I'll be removing it soon as I'll need the space for a Garmin G5. To tell the truth, I only put it in to avoid any argument at airworthiness time. Never looked at it in flight and can't imagine any case where I'd need it. I have 2 GPSs, one in the panel and the another that drives an iPad mini with foreflight, plus my phone is a pretty handy navigator, 2 alternators and a battery for pretty reliable power to drive the built ins.
About the only thing my panel mount compass has done for me is drip baby oil on my leg when I get up to about 12,000'. (topped the unit off with baby oil on installation) That thing's gotta go!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 04-03-2017, 11:43 AM
Rupester Rupester is offline
I have an Airpath whiskey compass in my panel ... works fine as long as you obey the compass card. At some headings the apparent reading is off by as much as 10 or 11 degrees.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-05-2017, 04:05 PM
bschweinberg bschweinberg is offline
Fly with the canopy open then.....
Bill Schweinberg
West Chester, OH
N2814X Reserved
RV-14A Started Nov 2013
Builder #140100
Empennage/Tail Cone DONE! (95%)
Wings In Progress (90%)
Fuselage Ordered March 2017
Finish Not Started
http://www.mykitlog.com/bschweinberg (not up-to-date)
=VAF= 2017 Dues Paid
Old 04-05-2017, 05:46 PM
RV6_flyer's Avatar
My RV-6 has been flying almost 20-years with a panel mount 'Airpath' compass.
My panel was designed so that there were no electrical wires or anything made of steel near the compass so that it would be accurate. Yes the Needle Ball is electric and the only thing near by but bench test before install only showed a 3 degree compass change. Unable to measure any change in the actual panel.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 07-01-2017, 11:53 PM
jpowell13 jpowell13 is offline
Default My outside the box compass mount
I had my vertical card compass mounted below the panel between my legs on my 6A. It was usually 15 degrees off. In getting ready for a long x-country, I removed the compass, mounted a VAL INS429 in the spot and ordered a magnetometer for my Garmin G5 backup EFIS. Well, the magnetometer didn't arrive in time for the trip, so, I bought a bracketron TripGrip suction cup phone mount from Best Buy and stuck the compass to the canopy with a cable tie to stabilize the arm against the glare shield. I'll take it down once the magnetometer arrives, but I am surprised how well the setup works. The compass never disagreed with the GPS magnetic heading by more than about 5 degrees, and the compass stayed firmly in place during the 20 hours of x-country.
I'll probably use the phone holder to hold my Samsung phone once I get rid of the compass. I think the cost of the holder was about $30.
John
