Old 09-30-2016, 02:51 PM
JimMac JimMac is offline
Default Backup for Electrical System Failure
I just bought an RV-12 with the SkyView 10" display. Does anyone have any comments about what equipment one should have for a backup if the SkyView is inoperable and you find yourself in marginal weather over unfamiliar terrain? I suppose that a hand-held radio, manual compass and a portable GPS would be sufficient to get out of trouble. Any other thoughts?
Old 09-30-2016, 03:31 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default Ipad
I'd go with an iPad Mini (with ATT or Verizon option so that you get the built-in GPS) with Foreflight--self-powered, gives you moving map--just missing the attitude info. Our Skyview once showed us flying 7000 ft BGL (below ground level) for about ten minutes, but the Ipad told us otherwise, until the Skyview slowly got its bearings.
Rob Reese
RV-12 #332
N73HR Now flying!
Austin, TX
Old 10-01-2016, 08:29 AM
John-G John-G is offline
Default Add some 2 1/4" backup instruments
Jim,
You could consider adding some 2 1/4" backup instruments as I have done. I used instruments from UMA. UMA was also willing to silk screen the white and green arcs, ect. on the airspeed indicator.
I installed a vertical card compass as well, but not sure how well that will work out as I have yet to try to swing the compass. First impressions are it will be OK ... but will not know for sure until later in the week (weather permitting).
Plan to also have a notepad as a backup on cross country trips ... plus have Garmin Pilot on my smart phone as a backup for the notepad.
Return from the future: Was not able to swing the PAI 700 vertical card compass to my satisfaction even with compensating balls and Mu-metal. However, an Airpath C2300 compass was able to be successfully swung ... see post 18 in this thread for more info.
Below is a photo of my panel.
Happy flying,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 10-01-2016, 11:23 AM
Bill_H's Avatar
Bill_H Bill_H is offline
For the given situation, an Iphone with Foreflight or equivalent would be all that you would need if you are VFR. You could even call ATC on the phone without a backup radio. Might want a headset adapter for the phone.
Old 10-01-2016, 01:15 PM
tomkk's Avatar
tomkk tomkk is offline
My phone doesn't work above a couple of thousand feet ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 10-01-2016, 01:55 PM
BobTurner BobTurner is online now
I find it curious that no one has said, "Carry a map".
Old 10-10-2016, 08:39 PM
Bill_H's Avatar
The GPS part of the phone works fine at any altitude.
Old 10-10-2016, 09:09 PM
tomkk's Avatar
But I don think "You could even call ATC on the phone without a backup radio." ...
Tom
Port Orange, Fl
Old 05-18-2017, 03:31 PM
AirHound AirHound is offline
John and all,
Any luck with the standby compass? Anyone install a liquid filled/whisky compass? What is the logic, all be it legit, to not have to have a stand alone none-electric compass?
Thanks for any ideas.
Doug in IL
Originally Posted by John-G View Post
Jim,
Happy flying,
Doug
Old 05-18-2017, 04:00 PM
N941WR's Avatar
N941WR N941WR is offline
Add a Dynon D2 Pocket Panel and a Garmin 660 Aera.
You can wire the D2 and 660 into your electrical system so they are always charged. These two units are simple to install and light.
If you are really worried, toss a handheld radio and extra batteries in your flight bag.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
