Old 04-17-2015, 07:56 AM
Pilotman Pilotman is offline
Default Carburetor Sync Equipment
I want to build the test fixture for synchronizing the carburetors. Any suggestions with associated piece part sources would be appreciated.
Old 04-17-2015, 11:43 AM
I use the electronic Carb Mate from California Power Systems, but at the ROTAX course the instructor had a neat setup using a manifold pressure gage from a twin engine aircraft. He just adjusted the carbs to get the gage needles on top of each other.
Old 04-17-2015, 02:30 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Two for the Carbmate. Keith drop me an email. I'm over at 16X west of Justin TX. I'd be happy to hook up and help you do the carb synch. John
Check out the videos here:
http://rotax-owner.com/en/
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 04-18-2015, 04:47 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Simple synchronizer
Remember the old days when we had MGB's and Honda 750's with four carbs? We used a manometer stick made with cheap Tygon and plastic or glass tubing.
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 04-18-2015, 08:59 AM
Thanks for the information!
Old 04-18-2015, 06:57 PM
Sink Sink is offline
Banned
I was taught in school that the Carbmate and Syncromate were okay, but you an not diagnose with them and it is much harder to pick a carb you want to adjust. The analog gauge setup tells you which carb to adjust and by about how far. It can tell you if the ideal circuit is obstructed or if the carbs are so far out you need to adjust the cable length on the throttle arm. The electronic sync instruments can split a hair, but once you disconnect it and hook the carbs back up all the hair splitting is gone. Gauges are just so much faster.
Old 04-18-2015, 08:38 PM
I agree for all the reasons mentioned.
In our shop we use the two column version of this.
http://www.carbtune.com
Scott McDaniels
Hubbard, Oregon
Old 04-18-2015, 08:40 PM
Joe, if you have the mechanical synch correct the Carb Mate should work fine. My engine runs really smooth at and idle of 1800.
Rich
Old 06-18-2016, 03:03 PM
Tony_T's Avatar
Tony_T Tony_T is offline
I have a Rotax 912 gauge set for sale on the classifieds:
http://www.vansairforce.com/communit...69&postcount=1
Tony
RV-12 #202 -- Flying
Old 06-18-2016, 08:50 PM
Jim T Jim T is offline
Tony, Your post and ad begs the question: "What did you upgrade to, that is a better setup"?
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
