Old 06-14-2014, 05:05 PM
TomVal TomVal is offline
Default Lower Canopy Rail Gusset...
Installed left and right reinforcement gussets to canopy rail.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 06-14-2014, 08:01 PM
rgmwa rgmwa is offline
Good idea. Think I will add one too.
rgmwa
120346
Old 06-14-2014, 08:22 PM
Tom do you remember what gage of that aluminum is? We just removed the canopy for fiberglass trimming it looks like a perfect opportunity to add the stiffener.
Old 06-14-2014, 08:47 PM
Actually, I'm not sure. The aluminum came out of the floorboard of a 1947 SeaBee. As with you, it looked about right so we used it. It had original primer on it. We just cut, drilled, lightly scotchbrited, reprimed, then installed.
Regards,
Tom Valenzia
RV8 (Sold)
Old 06-14-2014, 08:50 PM
I'm using 0.025" from some spare fuselage skin that I have. That will be plenty for this job. After all, that's all that supports the other side.
rgmwa
120346
Old 06-14-2014, 10:38 PM
I'm not sure what problem this addresses. Have people had problems with the canopy frame?
Old 06-15-2014, 12:21 AM
I buckled one of these upper frames by accidently leaning on it during the build with just a few clecos securing it to the skin, so that doesn't really count. However, I tend to grab that area of the rail when getting in or out of the plane and think a little more stiffness there would be a good thing. And it gives me an excuse to make something.
rgmwa
120346
Old 06-15-2014, 06:05 AM
Unhappy Heavy Pilot Issue
I am not very flexible. Sometimes I will bear some weight on the rail while settling into or getting out of the seat and have noticed some flexing of the rail. Until I lose more weight (have recently lost 15 pounds) or inherit a more flexible body, I thought this modification would better support that area.
Regards,
Tom Valenzia
RV8 (Sold)
Old 06-15-2014, 11:45 PM
Thanks. I thought there was another generic gotcha out there.
Old 06-16-2014, 06:07 AM
BigJohn BigJohn is offline
What is that object just below the slot, looks like maybe a locking mechanism?
VAF paid through 10/2018. Best bargain in town.
