Old 08-13-2017, 09:22 AM
bryanflood's Avatar
bryanflood bryanflood is offline
Default Rv-10 oil cooler size
Hello all,
I have heard some people having high oil temps on the eve-10 with the 20006a oil cooler. It appears that this oil cooler has about 5" x 5" of cooling area, looks like 12 rows. If I look on the airflow systems webpage the 20009a model appears to have about 5" x 7.5" of cooling area, 17 rows I think. This oil cooler is just about 2.5 inches longer and should offer a bit more cooling capacity. The mounting under the cowl would certainly need to be different.
Has anyone tried using this larger oil cooler to get their temps down? I was thinking about this to be a little easier on the expensive engine.
Bryan
Old 08-13-2017, 10:31 AM
Originally Posted by bryanflood View Post
Hello all,
Bryan
No actual flight experience on the -10, but based on living in the South (I do) and wanting to eliminate oil cooling as a potential issue for my soon-to-be RV-10, I substituted a 8001649-NE cooler from Pacific Oil Cooler Service as a higher efficiency, drop-in replacement.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 08-13-2017, 11:13 AM
DRMA DRMA is offline
I've been talking with Bill of Airflow Systems and his recommendation for the RV-10 with IO-540 engine is their AS-2007X cooler. He even has a set of plans that show how to mount it to the standard Van's RV-10 oil cooler box so that it fits without modification of the cowl or other FWF equipment. The 2007X is only 1" taller than the stock RV-10 cooler.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2018 VAF Dues Paid
Old 08-13-2017, 11:27 AM
Carl Froehlich's Avatar
I'm running the AirFlow 2006X on a stock IO-540 from Van's. Never had an oil temp problem. I did however mount the cooler horizontally on the firewall instead of using the Van's oil cooler mount. The Van's mount just looked like too many airflow directional changes to me. I do have a 4" butterfly valve on the air inlet to the cooler as without it oil temps are too low anytime other than summer.
Carl.
Old 08-13-2017, 11:31 AM
rocketman1988 rocketman1988 is offline
Default Oil cooler
I opted for a compromise.
I went with the 2007X, which is a 15 row cooler. It was a very minor mod to the original mount, and should provide additional cooling over the 13 row model. Total mod time was only an hour or so.
I looked at the 2008X for a very long time before I made my decision. I think it would fit but not on the original mount without significant modification.
I think the best way would be to mount the cooler perpendicular to the firewall and use one of Airflow Systems Plenum ducts to supply air to the cooler. This would require removing (or not installing) the VA-186 oil cooler mount on the firewall. The perpendicular mount wouldn't really be a problem, and I think routing the 4" scat from the plenum could be done. I think that setup would give a much better result than the stock mount.
My decision was based on the fact that the VA-186 was already mounted, as well as the engine mount and engine. Let us know which way you go...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Dues Paid 2017,...Thanks DR+
Old 08-14-2017, 08:51 AM
Dorfie Dorfie is offline
Default 2007X
I installed the 2007X. It is an easy install with minimal changes to the Vans oil cooler mount. I did install an airflow controller in the duct to the oil cooler. Have not used it yet. Oil temps steady at 196F.
I know the guys in South Africa install the 2008X, mounts in the same Vans oil cooler mount. The oil hose attachment orientation is are 90 degrees to standard (Vertical vs horizontal). It was done in response to excessively high oil temps. Jannekom (Jan Hanekom) on VAF has detailed pictures on the 2008X installation.
Cheers.
Johan
Dorfie
RV10 Flying, N245JM
2018 dues paid with a smile
Old 08-14-2017, 08:57 AM
Auburntsts's Avatar
I've got the stock cooler with stock mounting and typically see oil temps in the high 180's to mid 190's in cruise with Sea Level temps in the mid 90s. It will spike on climb outs on hot days to as much as 210-215, but cools off quickly once I level off.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-14-2017, 08:33 PM
WrightsRV7 WrightsRV7 is offline
Default stock cooler works great!
I fly in some of the hottest weather in the country, gateway to death valley...need I say more. I depart with ground temps at 110 and have no issue with oil temp whatsoever using the stock cooler and Vans baffling. Cylinder temps in climb take much more attention with adjustment in climb speed. Second nature in my world. In the climb, yes it will get above 200 in the hottest weather, think once it hit 205, but look at the Lycoming NORMAL operation numbers, this is nothing. When I fly tow-planes we continually have the needle resting on 240 mark.... Just one very stock system/data point (RV-10) that is operating in a very temp-hostile place.
Michael Wright
Dues paid 2017
RV7 built & sold, 500h of pure joy in the air: sold
RV10 slow build & flying & loving it
Old 08-15-2017, 01:25 AM
woxofswa woxofswa is offline
Living in AZ, I opted for the Airflow Systems 07 sized cooler. Very easy mod for the standard bracket, just remove some frame material to make the opening larger and mount some angle stock atop to affix the nut plates for the larger footprint. I also have the AFS sharkgills in the side of the cowl and abeam the cooler on that side. They came with the AFS A/C kit. Not only have I never had hot oil temps, even in 110 degree weather, but I was having difficulty staying in the green in the winter time. I ended up adding the butterfly valve to be able to precisely control the temps in all conditions. It works very well.
I like the erring on the cool (conservative) side and the flexibility of the valve, and would build the exact same way again. However, barring extreme situations, I think that the standard setup is adequate.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 08-23-2017, 06:06 PM
rjarrell's Avatar
rjarrell rjarrell is offline
Default Oil cooler 90 degree Airflow Bracket
Has anyone installed the "ASIK-03: 90-degree bracket" and repositioned their oil cooler for this bracket. I have the parts but it looks awful tight, just hoping someone has done it and could share some pics. BTW RV-10 with Aero Sport power I0-540 SPL engine. Using upgraded cooler Airflow 2006X on the standard 45 degree Vans cooler mounted to firewall. Thanks
Rodney RV-10 "LIBERTY"
Dues paid 2018
