Old 07-23-2017, 02:33 PM
JOEPILOT JOEPILOT is offline
Default Charging issues
Ready for inspection but can't get charging system online. From what I have read the C wire, ( control wire ) should match battery voltage inorder too turn on the generator. I'm not seeing any volts there. Has anyone else had this problem?
Any input is greatly appreciated.
Joe
Old 07-23-2017, 04:36 PM
tomkk's Avatar
tomkk tomkk is offline
I had a similar problem. You can read about it here http://www.vansairforce.com/communit...=113005&page=3 starting at post 25.
I believe the 1A fuse on the Switch & Fuse module module is blown, not sure why. I'm experimenting with running with the "C" wire connected to the R/B+ terminal. I haven't yet decided whether to send the S&F module in for repair.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; ready for engine & avionics
Old 07-23-2017, 05:51 PM
Thanks, I checked all 3 of the 1 amp fuses, they seem to have continuity.
I'll double check next time out.
Old 08-06-2017, 12:50 PM
Default CHARGING ISSUE SOLVED
The 1 amp, amps A fuse on the printed circuit board was blown. Replaced it, now it's putting out 13.8 volts. Ready for inspection.
Old 08-06-2017, 01:10 PM
Joe,
Which airport did you choose for the base?
Old 08-06-2017, 02:20 PM
tomkk's Avatar
Joe, check your Private Messages ...
Tom
Port Orange, Fl
