Old 07-25-2017, 02:46 PM
mfleming's Avatar
mfleming mfleming is online now
Question Fuel Tank T-708 Question?
I'm ready to match drill the T-708 mounting plate to the T-703 end rib on my left fuel tank.
There doesn't seem to be any guidance in the instructions for what drill bit size to use.
The call out for the nut plates say's K1000-08. This would normally (I think) use a #19 bit.
But What cleco do you use for a #19 hole?? The instructions say drill and cleco the T-708 plate but none of the clecos I have are the right size...
I guess I could use -8R8 machine screws as I go along but that doesn't seem right...
Am I using the wrong size bit?
Help!
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Empennage (sans fiberglass)
Ailerons and flaps complete.
Wings done (sans fiberglass)
Started on QB fuselage
Donated 2017
Old 07-25-2017, 03:02 PM
Raymo's Avatar
Raymo Raymo is offline
That is the correct size bit for a #8 screw. There are associated clecos for that size as well as other, larger ones that you'll likely need at some point. They also make shorter (aka stubby) versions for tighter spaces.
EDIT: You can drill initially to #30, cleco, then drill up for the nutplates.
Are you using a nutplate jig? Well worth the cost!
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 07-25-2017, 04:36 PM
mfleming's Avatar
Thanks for confirming the #19 drill bit is the right one.
The 5/32" cleco's must be the ones I need...I've never seen the black ones on peoples build logs and Van's doesn't list them as necessary. Oh Well...
I decided to use some hardware store 8-32 screws and nuts to hold things in place as I drill.
Not using a nut plate jig...just a nut plate with a stud in place to align things.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Donated 2017
Old 07-25-2017, 11:46 PM
Bevan Bevan is offline
Michael, you will get a LOT of use out of the pro-made nut plate jigs. I strongly recommend you get yourself #6, #8, ,#10(AN3) sizes. You will use them hundreds of times and save lots of time and frustration.
Bevan.
RV7A Flying!
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 07-26-2017, 01:22 PM
mfleming's Avatar
Bevan.
Convinced!
I had to make a Yard Store order so I included nut plate jigs!!
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Donated 2017
