Saville
Hi all, I was thinking of installing a GPS puck in one wingtip. To do that, of course, requires that I run the antenna cable the legth of the wing and into the fuselage.
What, if anything, are the effects of cable length on GPS antennas?
I also have a Stratus external GPS antenna I was thinking of installing in the wing tip as well - in the hopes of not losing GPS lock when pulling loops. It's a small thing - about 8 inches long. Would the cable run cause the antenna signal to deteriorate?
thanks
thanks
