Old 03-06-2018, 07:48 PM
Geeman Geeman is offline
Default Taxiing the Tip up partial open.
I just purchased an RV-7 tip up (previous RV-6 slider owner) and was looking for ideas on how to support the canopy partially open while taxiing. Itís only March and I can tell itís going to be brutal in the Texas summers.
Kyle Gee
Purchased and sold flying RV-6
RV-7 Kit (sold to purchase C150 to train my kids)
Purchased flying RV-7
Old 03-06-2018, 07:55 PM
FLY6 FLY6 is offline
Default Open tip up
Not sure if the 7 has the same handle for lucking on the roll bar as the 6. If it does, I just open the canopy, place the handle as if locked and rest it on the roll bar. Not as much air as an open slider but it does make a considerable difference.
Al Grant
Flying RV6, O-320
Stoney Creek, On
Dues Paid
Old 03-06-2018, 08:14 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Another tip: configure the safety handle such that it still locks with multiple layers of shrink tubing on the tab that will rest on top of the roll bar while you taxi....
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1620 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 03-06-2018, 09:14 PM
Sam Buchanan's Avatar
been here awhile
Here is a photo I found in the VAF archives of a tip-up in the taxi position:
Once the fan is blowing a lot of air moves through the canopy, TX summers will be OK.
Enjoy your new RV!
P.S. I managed to take-off once during the chaos of S-N-F departures with the canopy propped open....the blast of air felt fantastic until I realized I wasn't supposed to be feeling a blast of air.....the canopy will ride about 6" open and can be pulled back shut if you slow to flap speed....forget closing it at cruise speed.....
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 03-07-2018, 12:37 PM
Default Fly the airplane
Sam, that is good information, I saw the results of a pilot trying to turn back to the field in a hurry because he took off with his canopy opened. The plane was a write off but he survived. I have taken off with the side lock in the unlocked position and was able to lock it once I slowed down. I aborted take off once when I started the roll and realized the canopy was still not locked at all. Just to confirm, there was no adverse flying conditions caused by the opened canopy nor any damaged caused by the open canopy.
We all like to think it can't happen to me, but it does and it is good to know the results prior to it happening.
Al Grant
Flying RV6, O-320
Stoney Creek, On
Dues Paid
Old 03-07-2018, 01:08 PM
been here awhile
I found out after the fact that I should have slowed the plane more, I was climbing out in a mass departure and was not yet at cruise speed. But the canopy was so hard to close (115 kts?) that I thought the latch would be damaged. But it was fine with no trim problems while flying with the canopy riding open.
Sam Buchanan
1999 RV-6
Old 03-07-2018, 01:37 PM
davevon davevon is offline
Slow to flap speed and lower the flaps to close the canopy helps a lot. Changes the airflow angle over the canopy.
Dave von Linsowe
VAF Supporter
C-140 (sold)
Tri Pacer/Pacer conversion (sold)
RV-4 kit (sold)
Pitts S-2A (sold)
RV-6 (sold)
Christen Eagle project (sold)
Pitts S-2B (sold)
Laser 230 (flying)
RV-6 project (sold)
RV-6 (flying again)
Old 03-07-2018, 05:53 PM
Jpm757 Jpm757 is offline
I had a tip up on my 6, and I cut a notch in the forward face of the roll bar that allowed the aft portion of the latch to rotate "into" and lock the canopy open several inches.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 03-07-2018, 08:44 PM
catmandu's Avatar
catmandu catmandu is offline
That is some goodly advice, thank you!
And yes, people, the tip up flies just fine with the canopy unlatched, just a little different. BE A PILOT! FLY the airplane, don't panic!
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 03-07-2018, 10:02 PM
6ato14a 6ato14a is offline
Default My latch
had always worried about my canopy blowing open while taxing so a couple years ago I made this upper latch modification for my 6a. After seeing the "canopy incident" on this forum that occurred in Switzerland I'm glad I did. If you haven't seen the accident in Switzerland do a search for canopy incident
First picture is latch in taxi mode with nice airflow and second one is latch ready for takeoff.
First picture so I hope it works.
http://tgi.com/sites/default/files/s...?itok=_xx67Q6Z
http://tgi.com/sites/default/files/s...?itok=U9WrwdDE
I hope these old links work if not see below.
If you are interested in more info call me at 303-772.2202 or emailing me at klmoexpogmail.com
