Old 01-06-2018, 03:37 PM
recapen recapen is offline
Default Anyone here using a FreeFlight Rangr
Just looking to see if anyone has any experience with this product.
It is advertised on these forums and has a similar function set to the ADS-600B.
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
Old 01-06-2018, 06:32 PM
mdevans9 mdevans9 is offline
Default Yes, FreeFlight Rangr FDL-978-XVR
Bought this from Walt (ExpAircraft.com) a couple of years ago on a group-buy. It works great! ADS-B Out (2020 compliant UAT) and In. Has it's own WAAS GPS, and WiFi's ADS-B traffic and Wx to my mini iPad. Also, traffic to my GRT HS EFIS. Using it with a GTX-327 Transponder. Support from FreeFlight has been great! Only needed that support to get everything set properly.
Best regards,
Merrill
Merrill D. Evans
RV-7 Flyng!
N87EM
Old 01-06-2018, 10:13 PM
jliltd jliltd is offline
I have installed and am using two Freeflight Rangr Lites (out only). Excellent quality and good support. Freeflight was part of the original Capstone program that set the standards for ADS-B years ago. The Rangr Lites I installed are 2020 compliant UAT out with availability to squawk anonymous for VFR flight. The quality of parts and units are excellent.
Jim
RV-8
RV-3B
Old 01-07-2018, 05:58 AM
n816kc n816kc is offline
Default FF Ranger
I’ve been running it for 2 years and echo the comments above, also purchased from Walt. Once set up (had to consult FF support - very helpful) it has worked well with no hiccups. WiFi to my IPad and traffic feed to my GNC 430.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2018 =VAF= donor
Old 01-07-2018, 06:36 AM
Isaac's Avatar
Isaac Isaac is offline
Ditto what mdevans9 said about his experience with the FreeFlight Ranger.
I purchased my FreeFlight Ranger from VISTA AVIATION INC, Pacoima, CA back in 2014. Mine was an early production unit and when I got around to installing about a year after I purchased it, found that my pn/sw version was only able capable of providing four RS-232 serial ports and to be able to display traffic etc. on my EFIS needed 5 serial ports. By this time, the newer versions of the Ranger had the capability to support up to 5 or even 6 RS232 serial ports. I contacted FreeFlight Tech support explained my dilemma, was able to return my unit, have it upgraded it to the current version at the time under warranty which solved the issue. So like mdevans9 said, tech support from FreeFlight was excellent.
It works great! Transmits traffic and weather to a GRT HS Sport EFIS. ADS-B Out (2020 compliant UAT) Out and In. Has it's own WAAS GPS, and WiFi's ADS-B traffic and Wx output using an external mounted module. I didn't wire the WiFi capability so can't comment on how it functions. I am using it with a GTX-327 Transponder.
___________
James
RV6 N947J
Old 01-08-2018, 04:18 PM
TW614 TW614 is offline
Default Free Flight
I'm installing one now. Just waiting for more shielded wire from Stein. A configuration or wiring error caused me to fail my performance test before Christmas, but the tech support has been nothing short of excellent. Install includes an existing ACK Mod 9 and a GTX 327. The only failure on the report was pressure altitude so I'm re-wiring and will reconfigure the control head. This is my first time to build a wiring harness and there was a learning curve on my part. Due to the other segments of the report, they gave me an extension on the rebate period. Jim Berry - Abilene TX
Old 01-09-2018, 08:23 AM
dougweil's Avatar
dougweil dougweil is offline
Mine is coming up on three years old and other than one software upgrade, it has been perfectly fine.
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 630 hours
Based Lake Elmo, MN (21D)
Old 01-09-2018, 09:28 AM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I was looking at the 978 Lite model ADS-B OUT option.
Gulf Coast Avionics has it discounted @ $1695
https://www.gulfcoastavionics.com/pr...ut-system.aspx
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1050+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
Old 01-09-2018, 10:28 AM
Brockster Brockster is offline
Default Ranger Lite In & Out
Installed Ranger Lite In & out this past August. Instructions were well written and there tech support is very helpful. Had many questions for them before I purchased system. Used with GTX-327 and IPad. Approved on first test flight and had rebate check within a couple weeks.
Paul Dannebrock
RV-9A, Flying
