Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 07-19-2017, 08:28 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Hope you
Originally Posted by uk_figs View Post
If I read this correctly with my GDL 39 D, GTX 327 and 796 this solution would make me ADS-B compliant, is that correct? Quite a bit cheaper than replacing the 327 with the 335 transponder and less behind the panel work. I assume that the GDL-82 GPS would become the master?
Figs
Figs,, Hope you are correct on this! My airplane has the same ,, 327 and 796
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 07-19-2017, 08:49 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Very interesting solution to the problem of our motorglider project. It's got a simple MGL panel, and I have been wondering what we'll do for transponder and ADS-B. Well.....I just took the 327 out of the RV-8 and replaced it with a 345. So I could put the 327 in teh Xenos, add this little box - and I have "Out". Don't really need "IN", but if I need it, that little $199 dongle from ForeFlight is interesting.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-19-2017, 09:05 AM
pvalovich pvalovich is offline
Default Replacing 327
Paul - any chance you can report the details of your 327 replacement with a 345? I'm thinking of doing the same but am worried about space and wiring.
Old 07-19-2017, 09:20 AM
Ironflight's Avatar
I know you;'re talking about your -8, so I understand the worry about spacing. If the back of your transponder lines up with the cross-bar, then it is VERY tight - I had to use a 90 degree BNC adapter to make it work, and massage how the wires come out of the Garmin connector on teh back of the box so that they went sort of sideways instead of straight out the back. It does fit - but it is close. If your transponder doesn't line up with the crossbar, you'll be fine.
Mechanically changing the rack took about 30 minutes - you can use the same screw holes for both 327 and 345 racks.
The wiring changes are minimal and easy - just keep track of which serial channels are going where. Because I mix and match various brands for testing, I had to do some research to make sure how the GRT EFIS., TT Autopilot, Avidyne 440, and Garmin 345 would talk to each other - and still make sure I coudl slide the Avidyne out and put a 430W back in!
Paul F. Dye
Old 07-19-2017, 01:16 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Than you Paul for answering a question I've been pondering about the spacing. My 327 is mounted at the cross bar level. Maybe it is a non
issue now!
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 07-19-2017, 08:07 PM
N427EF N427EF is offline
Default wondering
wondering why this GDL 82 is not getting the attention.
GDL 52/51 seems to get all the reviews and yet almost everybody has some sort of ADS-b in already.
It is ADS-B out that seems to be the issue for most people especially those with a 327tx.
Just wondering out loud why this neat little box is not splashed all over the front page???
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 07-19-2017, 09:14 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
I'm very excited about this product myself and was wondering the same... I thought I was maybe missing something.
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 07-19-2017, 11:36 PM
RV-4 RV-4 is offline
Cool GDL-82
Gil, you say
´´Works in the US....no trip to Canada''
Did I miss something...is that new box program to stop working at the border..
Bruno
2018 Due paid gladly
Old 07-20-2017, 05:35 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by jliltd View Post
With the GDL-82 being a UAT out product, does it have anonymous mode capability when squawking VFR like other UAT products?
Hello Jim,
Yes, you can configure the GDL 82 to transmit in anonymous mode anytime the transponder code is set to 1200.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-20-2017, 07:20 AM
BKK117 BKK117 is offline
Default Anonymous Mode
Not to beat a dead horse and this product looks very promising, but in anonymous mode does ATC still get an A/C identifiable code they can track?
I'm honestly not as concerned about other aircraft knowing who I am as I am Uncle Sam riding along.
Your website states that it de-identifies you to other aircraft but it doesn't say if ATC can identify you.
Bryan Knight
Melbourne, FL
RV-8
