ccsmith51
I am considering a 1996 RV-6. It has 295 TTAF. It has an O-360-A4A with 1602 SMOH. I am told this (paraphrasing a couple of e-mail's):
--- In Feb 2000 at 113TT it suffered a prop strike on a grass strip on take-off. I went to the far north end and turned to the south for takeoff. I gave it full power and when I could lift the tail the landing gear dropped into a hole and the prop struck the turf shattering it on impact. The engine continued to run and I had to shut it down.
I put a dial indicator on crankshaft. Absolutely no run-out.
The first prop was a Bernie Warnke Almost Constant Speed prop. I bought the replacement prop from his daughter. ---
I think I can assume that the engine was not torn down for inspection. It also sounds like the engine has about 180 hours on it since the prop strike.
So, my questions:
- Should I just walk away?
- If the engine has run fine for 180 hours since the incident is it safe to assume that no damage was done to the crank or accessory case parts?
- Any other questions I should ask?
So, my questions:
