Old 10-21-2018, 06:24 PM
goatflieg's Avatar
[quote=WingsOnWheels;1296547]Adding a few more pictures. Painting has been a little slower than I like. It has been raining almost every weekend for the last month and a half, and now it just got cold. Just bad painting conditions all around. But it is done now. I just finished the second wing. Still have to do the wheel pants and gear leg fairings, but that will be down the road a bit. For now, it is time to start bolting this thing together.
I feel your pain. I want to get my belly painted while the fuselage is upside down... but lots of rain, fog and high humidity have delayed it. Now it's getting cold in Michigan, and I had to devise a way to heat the incoming air to the booth without risking death. I think I might get it done in the next couple days, though. Wish me luck. Your paint work looks excellent!
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 10-23-2018, 06:19 AM
WingsOnWheels WingsOnWheels is offline
Originally Posted by mbauer View Post
Thank you for the estimates on the cash outlay, in particular curious about the paint booth cost.
Any tips on construction? Was thinking of using 2x2 and then a thin strip of wood to hold the plastic in place.
Did you notice any places where the plastic was pulling loose from just the staples? Did the filters plug up with paint?
The spinner looks fantastic, overall really like the blue color you used.
Thanks for sharing the photos.
Best regards,
Mike Bauer
Edit: to actually answer your question, the paintbooth was around $200-250 all said and done.
For the most part the paint booth has held up very well. A few staples have come out, but nothing significant. I have replaced the floor plastic a couple of times just to keep things clean. It only costs about $5 to do it, so cheap insurance.
For construction, just make the frame strong enough to hang mid-weight parts like the rudder, flaps...etc. Anything more than that is overkill. I like having only plastic on the inside. I spray the floor down with water before painting and have washed the walls down on occasion. a wood strip inside seems like a dust source. If you have a lip at the front like I do, run the floor plastic over the lip and out. That way you can blow dust out without it getting caught.
For filters, I am using the cheap home depot woven poly type ($0.98 each). They do a good job cutting out the dust and not hurting the airflow too much. If I were to do it again, I would add a third or maybe forth fan. The filter cuts the flow down by a good 50-60%. I have replaced the filters once for both inlet and outlet, they do get very dusty (mostly the outlet), but you can vacuum them out.
My original plan was to use an old home HVAC blower, I still think that would be best if you can find one cheap. For me nothing popped up at the time. OSHA spray-booth minimum is supposed to be 1mph flow rate so for an 8'x8' cross section: 5280/60=88ft/min. 88x(8x8)=5,632 cuft/min. If I recall, the fans were rated at 3200cuft/min each, but I didn't realize just how great the loss would be with the filter. That is why I suggest more fans.
Colin P.
RV-6A #20603:Painting Done, almost done with final assembly. Getting very close!
PP SEL / A&P
N616CG (Reserved)
I donate every year on my B-Day (in Dec)
Old 10-23-2018, 06:22 AM
Originally Posted by schaplerrh View Post
BEAUTIFULLY! Would you please come paint my plane.
Robert
Just don't get to close before you make a lot of compliments...haha
The small parts are easy and came out really nice. The larger ones aren't quite as nice. A little orange peel and some dry spray here and there. The white can be cut and buffed so that helps.
Colin P.
PP SEL / A&P
N616CG (Reserved)
Old 10-23-2018, 06:40 AM
Default Lessons Learned
Now that I am pretty much done, I just wanted to post a few more lessons-learned I am not going to rehash too much of what I already noted in prior posts.
1) Even though I read this myself a bunch of times and was told, metallics are very hard so shoot in single-stage! They are very prone to tiger-stripes and mottling. I was able to get it done, but it wasn't easy.
2) You cannot cut/buff single-stage metallics - even if they say you can, it doesn't work well. So plan on not doing it.
3) White is often harder to spray than the metallic. The first coat is easy, not the second coat. Just very hard to tell if you have a wet coat.
4) More light is not always better. I have overhead lights in my shop and I added 4 2200 lumen LED lights to the sides of the booth. It is too much, it just washes everything out. Most of the time I just turn on one or two of the extra lights. Ideally, you want the light around 70 degrees offset from to face of the part, so you see the reflection at and angle. Straight-on and you can't see a thing (more of a problem with the white).
5) Overall I am still pretty happy with the paint. For the topcoat a 4:1:1 mix worked well. I just switched between slow and medium activator depending on the temp. I used medium reducer for all. It is not as good as the PPG MTK I used for the interior, but it is a third of the cost.
6) If you are using the Van's pop-rivet static port, install them after paint. The paint builds up around the rivet head and may cause errors. I'll probably drill mine out and replace them. May need to touch up the paint around them.
7) Don't use plastic to mask anything (or put paper over the plastic). I wrapped my engine in plastic when painting the fuselage. The paint does not adhere to the plastic. When I went to topcoat, any primer that was on the plastic blew right off in large flakes (like quarter-size) and landed in the topcoat. A layer of masking paper over the plastic solved that problem.
Colin P.
PP SEL / A&P
N616CG (Reserved)
Old 11-17-2018, 10:10 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Thanks for posting all this, it helps to read your painting story.
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 12-01-2018, 09:29 AM
Eddie P's Avatar
Eddie P Eddie P is offline
Great read Colin! Great work too.
All up, how much additional weight do you think you put on with the paint?
Flying is Freedom
VAF Support / Dues Paid Through DEC 2019
Old 12-17-2018, 01:20 PM
Sorry for the delayed response. for weight, I really have no idea. Being an amateur, it is probably a little heavier than if a pro had done it. I would guess less than #20 though. Used less than 3 gallons of paint (probably 40% waste with overmixing, overspray, and practice panels). Then how much of the gallon remains as solids when the paint cures 30%?...just a guess. 12 pound per gallon x 3=36 x 60%=21.6 x 20% = 6.5 Plus the primer, I used less than 2 gallons, less waste, say 25% and higher solids so 50% weight, so #9 is conservative. That is a total of 15.5 pounds. No idea if that is even close....but sounds good.
Colin P.
PP SEL / A&P
N616CG (Reserved)
Old 01-08-2019, 11:13 PM
Eddie P's Avatar
Thanks Colin! I've seen a few "after paint" aircraft according to the scales add about 15 to 20 pounds. Each paint scheme is different, different pigments and how thick and if yes or if not show quality... makes a difference. Sounds just about right, and your explanation is satisfyingly complete none the less
Flying is Freedom
Old 01-10-2019, 03:07 PM
PrescottB787 PrescottB787 is offline
What kind of primer did you use?
Ken
Old 01-13-2019, 01:53 PM
I used the summit racing brand expoxy primer. I have been very happy with the primer. The price is right and it has held up very well.
Colin P.
PP SEL / A&P
N616CG (Reserved)
