Requested torque values
Bob - to answer your questions regarding thread sealant ? NO thread sealant on the threads of the flare fittings because the seal is actually made at the flare and not at the threads like a water pipe thread. Plus, the sealant will mess with the running torque of the fitting. I did put a very thin (and I mean very thin) coating of fuel lube on the mating face of the fittings just in case the line twisted a bit during torquing so hopefully there will not be any gulling if it does. Probably a superfluous step but I had it so I used it. Early section 5 plans mentions using fuel lube (mine does) but I was told newer versions of the plans make no mention of it.
As for the torque values for the flared fittings used with the soft aluminum tubing as in the RV-12:
Torque 1/4" flare fittings to 50-65 inch pounds.
Torque 3/8" flare fittings to 110-130 inch pounds.
The torques vary slightly depending on who?s chart you are looking at but you should be in good shape if you aim for 58 inch pounds for the 1/4" tubing?s flair fitting nut and 120 inch pounds for the 3/8" tubing?s flare fitting nut.
I was able to use a crowfoot wrench on the end of a torque wrench to do the final torque of the return line bulkhead fitting flare nut through the inspection port with the bottom skin on. Had the fuselage laying on its side with a second helper on the other side of the bulkhead through fitting holding it with a wrench to prevent twisting.
A little math is involved when using the crowfoot wrench on the end of a torque wrench because it will change the length of the torque wrench so the torque setting on the wrench needs to be adjusted down accordingly. I made calculations for straight and 45 degrees ? using the crows foot at 90 degrees basically requires no correction (should be within the margin of error of the torque wrench). Here is how I calculated the torques when using the crowfoot wrenches.
http://www.dogaviation.com/2014/01/calculating-torque-values-for-fuel.html
Although as the project moves forward, knowing a lot more tubing fittings will be installed in the not too distant future, suspect owing a set of inexpensive flare nut wrenches would not be a bad idea. For what it is worth, noticed Harbor Freight also has a set of crowfoot wrenches that are for flair nuts as well.
Happy building,
